HST Wine, Not any more
/ HST Wine, Not any more #1
Southern Manitoba Canada 1068 meters from the US b
Kubota Bx2350
Well here I sit with a busted tractor fan and the dealer won't get another one in untill Monday so what to do?
Well yesterday I took the roll bar off of the tractor as that was the easy part and if I had to pull the tractor apart I might just as well start there. After I removed it an amazing thing happened, I had to move the BX to where I would be working on in and there was no noise coming from the transmission, no wine no nothing, all I heard was the engine. Now I always thought that it was just the transmission that was doing the wining and that there wasn't much that one could do about it but I had never removed the roll bar before.
As it turns out that roll bar is just like a big tunning fork and when your on the tractor your right in the middle of it. So what to do? Well the first thing that I did was to make some rubber pads out of an old inner tube three layers thick to sandwich between the roll bar base and the mounting pads on the transmission. Bolted the roll bar back on and it made a big difference but the wine wasn't gone as the vibration still worked it's way through the bolts and into the roll bar, back to the tunning fork thing.
Somehow I had to deaden the vibration in the bar itself, so what I did was drill a 3/8" hole in the pads on the bottom of the roll bar and one 1/4" hole hole in the center of the bar on the inside top.
I then injected urethane insulation foam with a long 3/8" plastic hose attached to the can into the holes in the mounting pads untill the foam came out of the 1/4" hole on top. I just kept injecting foam while backing the hose out untill I had filled the whole bar.
This morning I reinstalled the roll bar and fired up the tractor, The WINE is GONE, I mean like really Gone. The sounds of silence, or just the sound of that little diesel doing it's thing, It's kinda nice.
Now before the kubota safety police come knocking at my door because of drilling holes in the roll bar , save yerself the trip cuz I ain't letting yuh in. It's my tractor and I can do with it as I choose. Now I'm not advocating that anyone else does this but firstly the holes in the 1/2" thick base plate make No difference whatsoever and if a 1/4" hole in the roll bar top destroys the the structural integrity of the steel in some hitherto unknown manner then perhaps Kubota should look into using a better grade of steel.
So for any of you who just can't stand that incessant wine any more it's just a thought.
/ HST Wine, Not any more #2
So your saying you now have an insulated roll bar ... cooler in the summer and warmer in the winter ... good job.
/ HST Wine, Not any more #3
Nice find and good solution.
Yeppers, I figure with that insulation on three sides that six pack of Coors that I keep hanging from the bar should stay nice an cool whilst I'm out mowing in those hot summer afternoons.:laughing:
/ HST Wine, Not any more #5
I was also thinking now that its foam filled it won't hurt so bad when you bump your head on it....
/ HST Wine, Not any more #6
I knocked on your door, but no answer. :D
I was going to tell you I discovered the same thing, and posted it in a thread here somewhere. I didn't fix it, since once I found out it was just amplified, and not that bad at the source, I didn't mind the whine anymore. But, you sound quite bright, (planning to make a fan out of stainless, beyond my skill level) so I wanted to ask you if you can tell from the frequency what the likely source of the whine is.
I guessed charge pump. Would you agree?
/ HST Wine, Not any more #7
You guys must have WAY better Coors than I can get here. Blah!
I have no idea, when it comes to hydrostatic transmissions I'm about as ignorant as a person can get. Now I can machine any of the parts in that transmission if you tell me what it is that you want and give me a blueprint of that part but as to what that part does? Not a clue.:confused2:
/ HST Wine, Not any more #9
Excellent work David!! :)
/ HST Wine, Not any more #10
So, how many cans of foam do I have to buy to silence my beast?:thumbsup::thumbsup:
/ HST Wine, Not any more #11
I would think Kubota would love to hear this story and they could put the foam in at the factory..
I dunno, depends on the beast me would be thinkin. But this is the stuff I used and I had lots left in the can, It's just something that I had on hand and it's a 30 ounce can. Think about it almost two pounds of foam is a lot of foam.
Now thinking about it silicone sealant would be even better But would cost a lot more
David
/ HST Wine, Not any more #13
I though this was going to be about how to make wine with your tractor, maybe to smash the grapes or something.
/ HST Wine, Not any more #15
A full two pounds of foam?? Have you given any thought as to how much more top heavy your tractor is as compared to a stock unit. Yes, you removed some metal when you recklessly drilled the holes, but I just can't condone this. And don't even get me started about hanging beers off your roll bar. The bubbles in the beer WILL NOT offset their added weight. I for one cannot condone this type of mutilation of a fine piece of equipment....
sigh, is the workday over yet?
Seriously though, good job and a great discovery.
I didn't say that I used the Whole 30 ounces,I said I had LOTS left over, I mean like 30 ounces would be bordering on the foolish not to mention downright dangerous. Might even have to put stabilizers on the little bugger or a helium balloon tied to the roll bar to keep it from falling on it's side.
/ HST Wine, Not any more #19
With that foam, maybe the tractor can float now also :laughing:
2022 EZ-GO ELITE...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
2002 FORD F-250 SUPER DUTY LARIAT SERVICE TRUCK (A64276)
2002 FORD F-250...
2022 Ford Expedition SUV (A61574)
2022 Ford...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65054)
(INOP) 2013 MACK...
2006 CATERPILLAR 307C EXCAVATOR (A63276)
2006 CATERPILLAR...
