Buying Advice Downsizing from Kioti CK20
/ Downsizing from Kioti CK20 #1
chelydra
Ditch Witch
I've had a CK20 hydro TLB for six years, and quite enjoyed using it. Had only planned to keep it about three years to do the landscaping, but it's just *so* handy to have around for any job that might come up.
However... I probably have no real need now for a BH, and would prefer a smaller machine both to regain garage space and to work in tighter areas. For example, if I could get something narrower than about 42" (wheels and blade), I'd be able to clear snow off a lot of areas that now require shovel or blower.
So I'm thinking of down-sizing to either a small skid-steer or subcompact tractor. The only skid loader I've seen around that size is the Bobcat S70, which is kind of expensive but very compact. People say not to buy a used one, as they're mainly used for demolition and pretty beat up by the time they're sold. I'd like to be able to lift at least 700~800 pounds in the loader, and push deep snow (bad drifts where I live).
Can anyone suggest some good choices? If I had to lose too much on the deal, I'd just keep the Kioti - at under 300 hrs, it's barely broken in, but probably only worth $12~13k. But something affordable and capable that's shorter, narrower and perhaps lighter would be more useful now.
Thanks for your thoughts.
/ Downsizing from Kioti CK20 #2
Better keep what you have.
/ Downsizing from Kioti CK20 #3
While I cannot comment on the subcut I have to say that i would keep what ya got. We have a S100 where i work that we use for snow removal and sweeping. It shines with a 60" broom on the front but the blade is nearly useless. overall if it was my money I wouldnt buy one. yea its better than a shovel but not worth the price tag IMHO.
/ Downsizing from Kioti CK20 #4
cheydra,
I agree to keep what you have and would suggest a ballast box should be shorter than the backhoe when needed. I would rather add the cost of the ballast box than trade the equipment. That would be a few hundred bucks compared to thousands spent.
/ Downsizing from Kioti CK20 #5
So, it seems you still need/want some kind of tractor but not the backhoe. Perhaps the solution is to sell the backhoe and as suggested by, Jenkinsph, is put a ballast box on the back. You should be able to put a bit of money into your back pocket as well. :)
These are all helpful comments, and I'm much obliged for your thoughts. Keeping the CK20hst is certainly an option. Selling the BH would make sense, too. I just feel like it would be a bit wrong to separate them, where this tractor is so well designed for the BH, sturdy and easy-on/off.
Mainly, a slightly smaller machine would actually be more useful to me going forward. So I'm looking for suggestions for something perhaps in the 15-20HP range, a little lighter and smaller footprint. Since there aren't any dealers close by, and it's not easy to get prices by phone, comparison shopping with green, blue, the other orange or smaller brands has been slow. If people here can suggest a few good candidates, I'll make the trip to those dealers, and see what a new (or well-treated trade-in) tractor or skid-loader might cost vs. what I can get around here for the Kioti.
Thanks again!
/ Downsizing from Kioti CK20 #7
Have you considered the JD 1026R? Or a JD X748? Or the MF GC series? BX's?
You'll be given up some performance and your wallet will take a hit too. I'd keep the CK20, load the tires, and sell the backhoe. Take the money and get a snowblower for the CK20.
Thanks for all these tips, and various suggestions for alternatives. It's odd how some manufacturers make it hard to collect all the data, like length, width, weight, and loader lift capacity.
After a few calls to dealers, I'm convinced that there isn't a simple tractor-loader out there that will do what I want and not cost too much. So I guess I will stick with what I've got for now.
Next step: get some weight on the back. Rather not load the tires to keep total weight low when needed for going over planted areas. Since this
http://www.tractorbynet.com/forums/kioti-owning-operating/133155-cheapncheerful-rear-ballast.html
wasn't quite heavy enough, I'll look for a second-hand ballast box. Still wonder if it wouldn't be easy to hang a truck engine block or a stack of auto flywheels off the TPH...
Thanks again-
Chelydra
/ Downsizing from Kioti CK20 #9
Since a ballast box is cheap, compact, and has the hitch built in I wouldn't bother with an engine block or other junk on the rear. You can easily get more weight on the rear of the tractor than you need.
/ Downsizing from Kioti CK20 #10
Again, thanks for all the good comments. Just for clarity, a smaller tractor would actually be *more* useful to me now. For example, the smaller JDs will take a 47" snowblower, which would take care of a lot of paths that I otherwise have to do with the Ariens (when the snow isn't too wet) or by hand (too often).
There's no doubt that the CK20HST is a far more capable machine, and I really like it. But the heavy work is done, and I'm down to lighter loading and snow removal. In both cases, just a little narrower would make the tractor much more useful to me. Hence the search for something smaller and affordable. Alas, the JD 1046 and X-series are pricey, and apparently too new for deep discounts. Kubota doesn't seem to have an under-50" blower as needed here. I'll probably keep the BH, and perhaps sell the whole outfit in the spring if I can find something suitable (perhaps used) to replace it.
Cheers-
Chelydra
/ Downsizing from Kioti CK20 #12
Cheers-
Chelydra
I mentioned keeping the CK20, because you said you needed 700 to 800 lb. lift capacity on the FEL.........smaller tractors just don't have that capacity.
To get the narrow width you desire, you are getting into riding mower territory, well below the SCUT level.
You could order something like an 'orchard tractor'. they have a narrow width, but from what I've seen they don't come with FEL's, but you could get one fabricated. I can only imagine how unstable they might be, and the price will be significant.
EDIT: Unless you look into Simplicity: http://www.simplicitymfg.com/index.cfm
/ Downsizing from Kioti CK20 #13
The small Kubota BX is right about in your wheel house, as you described your wants/needs.
If you have a chance to actually sit on one, or use one, you'd probably be thrilled. BX1860
/ Downsizing from Kioti CK20 #14
Just an opinion ... never ever downsize, you will regret it. You will find yourself trying to do jobs with a smaller unit that you used to do with a bigger machine and then you will regret it. Or break something !!
Pull off the hoe, add ballast, can you move your rear wheels in?... That would make it narrowed for a smaller blower ... now that I say that whats wrong with blowing a 5' walkway opposed to a 4' ??
I've been trying to find out about the rear wheels. However, I really am finished with the major landscaping here, and a smaller machine would be far more useful. Looking again at jobs I do, any loader capacity over about 500 lbs would be useful. And since I've very rarely run the CK20 at over 2500 PRM (vs. 3000 firewalled), I doubt that I'd need more than 15 HP or so. Re the blower, there's a max of about 51" between immovable objects in one key area.
Kubota BX looks like best option if I ever can afford to downsize. Need to get to a dealer to see if I can sit in one OK, and then hope that prices on new tractors drop a bit while used prices stay up.
/ Downsizing from Kioti CK20 #16
It sounds like to me your set to downsize ... so do it.
2019 MACK PINNACLE (A67714)
2019 MACK PINNACLE...
TWO PALLETS OF HYD TANK, V8 ENGINE BLOCK/PARTS (A68842)
TWO PALLETS OF HYD...
2020 CATEPILLAR 289D3 SKID STEER (A65056)
2020 CATEPILLAR...
2025 Hydraulic Tire Lifter Skid Steer Attachment (A66734)
2025 Hydraulic...
MQ MULTIQUIP PUMP (CONDITION UNKNOWN) (A68842)
MQ MULTIQUIP PUMP...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
