Loader FEL capacity with a boom
/ FEL capacity with a boom
Thanks for all the input.
Some of the suggestions - like buying/renting a proper engine hoist are way too practical. ;-). If I did that I wouldn't have a reason to build the boom pole. Besides, the boom will find a hundred uses once I have it.
I got a deal 7.5 feet of 2"x2" square tube, x0.25" wall, and 8' of rebar for $25. I'll get started tomorrow.
/ FEL capacity with a boom #22
Make sure you take and post pleanty of pics of the build:thumbsup:
/ FEL capacity with a boom #23
LD1 said:
Yep. Brain fart:confused2:
That makes it about 322lbs. But either way, It is still just guessing at the measurments. I was kinda hoping the OP would post back with some dimensions so I could sketch it out and figure it to a TEE.
In light of my error, he would have the 460lbs @ about 4' out on the boom. Using my guestimated dimensions:thumbsup:
That estimate fits generally with my experience using a four foot tree boom. I would be confident of 400 lbs but 450 is likely.
/ FEL capacity with a boom #24
Since you also have a CK20 like the op....
@ 4' on the end of the boom, what (in your experience) has more power out that far, the curl or the lift?
Have you ever tried to lift something and found it just a tad too heavy but you could still curl it? or vice versa?
LD1 said:
I guess that would depend on why he is removing the engine:D
Me and a buddy scrap quite a few cars. So we dont worry about precision.
My 2 favorite ways we have pulled motors.....
1. Sawzall the front clip/core support off. Now that there is nothing in front, wrap a 3/8" logchain around the motor and transmission. (FWD car). A little slack in the chain to allow a ~10mph yank, and out she comes. Dont have to unbolt any mounts or CV shafts or nuthin:thumbsup:
2. Backhoe. Wedge bucket between engine and firewall and curl the bucket.:thumbsup:
The kid needs the tranny for his truck. No precision necessary, except for the need to protect hands as we unbolt it.
/ FEL capacity with a boom #26
You already know this, but it's way easier to drop the transmission out the bottom of the truck than out the front.
/ FEL capacity with a boom #27
4' from the pins on the 7520 the lift has more force than curl. Around 3'+ is the parity region.
larry
/ FEL capacity with a boom #28
larry
That probabally holds true on the smaller tractors as well.
I dont have a boom so I cannot test it, But my log-lifting forks are 24" long, and at the tips of them, I still have more curl power, but not by much.
My only other experience, as I mentioned, was with a 15' boom. And It wouldnt curl anyways near what it could lift.
/ FEL capacity with a boom #29
larry
Agree. About the same on the CK20.
/ FEL capacity with a boom #30
I find the max lifting capacity of my B26 with LA364 loader is pretty close to the tipping weight. That can sometimes be your real limitation.
/ FEL capacity with a boom #31
Real lifting capacity is a constant.
Tipping weight is variable. It all depends on how much ballast you use.
There is a BIG difference in tipping weight between nothing, a light blade, or a heavy bushhog or backhoe.
The tipping weight with nothing and no filled tires is probabally only 10% of what the hydraulics are actually capable of lifting with proper ballast. And UNLESS you can lift until the relief valve opens and the rear tires are still planted, you do NOT have sufficient ballast.
/ FEL capacity with a boom #32
I have made a few boom poles, can't seem to understand how you guys are lifting as much weight as you say. I tell you at 7 or 8 ft out it hasn't been a lot. I have never got near as much as some of you are saying.
Loading some pictures of my boom and what I did today with it. I do this 3 or 4 times a year just because I don't have a overhead anymore, and it can't be done with a cheerpicker. And I can tell you a big block is all you want with the ex manafolds on it with a 40 hp tractor and you had better not turn until the engine is down. The engine today is a 350 block, but keep in mind the manifolds weigh close to what the engine does.
I do this by myself and alot of up and down from the tractor. As you see my boom goes in and out. I keep it in when I'm R & R a engine because I want all the control I can get. Slow and easy!!!!
/ FEL capacity with a boom #33
So...Are you saying you had trouble lifting it, or.....you had trouble keeping the rear tires planted???
I dont know what you have for ballast out back, but it didnt look like much. On a tractor your size, you shoud have ~1500lbs MINIMUM to make full use of your FEL, which has a lift capacity @ the pins of ~2500lbs. And by looking at the pics, I would say with the length of that boom, you will still have about 1/2 or that at the end of the boom. So...~1250lbs
How much do you think that engine weighs??? A SBC is between 500-600lbs, depending on iron or aluminum heads and intake. So IF you are saying that the manifolds weigh that much as well, 600+600=1200lbs. Whats their to complain about:confused2:
/ FEL capacity with a boom #34
LD1
( Whats their to complain about) I wasn't complaining about anything, just saying I could never lift a lot of weight with a long boom pole. The tractor does good with the weight on the back and loaded tires.
Like I said I don't know the weight of the 350 block. The big think is, I have to get them so high to clear the boats. Sure gets hairy sometimes.
/ FEL capacity with a boom #35
It sure sounded like you were complaining. Not understanding how we can lift the weight we claim we can with a boom pole.
I just pointed out the numbers and calculations JUST like I used earlier in this thread. And it seems you are able to lift the amount of weight I calculated you can. Let me explain....
It appears your pivot pin is right almost exactally at the midpoint between the end of your boom, and where the cylinder is applying the force.
Thus, you would have ~1/2 of the pin rating avaliable at the end of the boom. Since your tractor is rated @ 2500@ them pins, that gives you 1250 at the boom.
If that same boom were on the tractor that started this thread, he has a lift of 1100@ the pins. So his boom lift would be ~550.
I guess I dont get what you "cant seem to understand".
/ FEL capacity with a boom #36
This is what it has listed for my loader. I think I'm starting to understand it now after what you just posted. The pivot pin was getting me. How long of a pole could I make before I get 0 lift? That is if everthing is right on the tractor side. I have no ideal how to calculate it. After I understood the pivot point then the other 2 # below made sense.
Lift capacity (pivot pin) 1129 lbs.
Lift capacity (bucket bottom mid point) 1874 lbs.
Lift capacity (19.7 in forward) 2509 lbs.
/ FEL capacity with a boom #37
something is backwards. Pivot pin capacity is ALWAYS higher than mid bucket or 20 inches forward (usually same as mid bucket).
It might make sense if these figures are reversed and the bucket is a long one but something is wrong with those figures.
zero lift would occur when the weight of the pole and distance from pivot pins equaled capacity at that distance. The longer the pole the less the capacity but to give you a precise answer you'd need to know the weight of the pole itself. There is a practical reason why boom poles are typically 4-8 feet long although special poles for lifting relatively light material can make sense.
/ FEL capacity with a boom #38
This came off the spec. for my loader. Now you can see how I couldn't understand it. Everything you are saying makes sense.
/ FEL capacity with a boom #39
Here are the specs Products: LA854 Kubota Canada Ltd.
You had them backwards, and I am still not sure where you came up with the 1100lbs at.
Because on your loader, the "bucket bottom mid point" and the "19.7"forward" are roughly the same:thumbsup:
Based on the good advice received here, I reduced the overall length of the boom. The little CK20 has limits. :)
The distance from the pins to the end of the boom is under 60". I've attached a few photos, but I'm not finished yet. I need to pick up some hooks and finish the welding. I'll test it before I clean it up and paint it.
I've also attached a picture of the trailer hitch I whipped up. I'm not an experienced welder, and I've got the cheapest welding equipment possible. With that in mind, I'd welcome advice from those who have better welding skills.
1970s John Deere 350B Dozer — Only 2,525 Hours — Single Private Owner 40 Years — Light Use, Ready to Work
1970s John Deere...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
1785 (A64280)
1785 (A64280)
2025 SAWYER 85BP20 20FT T/A ENCLOSED BUMPER PULL TRAILER (A59912)
2025 SAWYER 85BP20...
2019 FREIGHTLINER CASCADIA CA113DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59911)
2019 FREIGHTLINER...
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
