At wits end with battery?
/ At wits end with battery? #21
The fact that the engine won't turn over even when you jump it with other batteries suggest you may have connection problems as well.
Yes and no..if the existing battery is really dead and or shorted, just jumping might not help. Ive had to totally disconnect the old battery in the past a few times to get a truck to turn over. The dead battery just sucked soo much amperage that the jump didnt work
/ At wits end with battery? #22
I experienced the battery thing a while back on my Dodge Dually and listened to my TBN friends and replaced them ... good to go.
Just last week my tractor ... 2006 with 1000 plus hrs running my irrigation pump ... dead new battery and good to go.
/ At wits end with battery? #23
I have a closed cell gel battery I was thinking about putting on my tractor. I got it out of a wheelchair. I would have to find some metric all thread to make a new hold down though... If I had to buy a new battery right now I would put an Optima in it!
/ At wits end with battery? #24
Ive seen the Optimas at NAPA and im interested in them, but i dont know if they will work in a tractor (bump bump bump)
/ At wits end with battery? #25
I have had an optima in my trencher for three years (200+hrs run time) and no issues, I think it gets roughed up at least as much as a tractor would, especially when trenching hard ground.
/ At wits end with battery? #26
They use them on all kind of off road racing etc. Had one in my jeep, great batteries!
Haha I love coming here and reading y'alls post. Very good information in them. I finally replaced the battery (again, choice words and bloody knuckles) and as soon as I turned the key it turned over and started. Quickest start I have seen on any vehicle, let alone a tractor.
/ At wits end with battery? #29
Glad you got it going..Now you could decide to use some sort of Battery Maint. to keep it up and in good shape.I know some might say to not bother, but I have a battery now going on over 10 years and only reciently decided that I would use a tender.At this point to extend out the battery life.
They have come a long way withe the tenders, right now Im using the Harbor Freight el cheapo,Glad you got it going..Now you could decide to use some sort of Battery Maint. to keep it up and in good shape.I know some might say to not bother, but I have a battery now going on over 10 ears and only reciently decided that I would use a tender.At this point to extend out the battery life.
They have come a long way withe the tenders, right now Im using the Harbor Freight el cheapo, and spliced in a connector for easy on and off.. and spliced in a connector for easy on and off..
/ At wits end with battery? #30
Automatic Battery Charger - 12V
Also purchased this one to sweitch between several other batterys.works great.
Walmart.com: Schumacher SpeedCharge Battery Maintainer and Charger: Automotive
And the wal mart one has a easy disconnect which is great..:thumbsup:
/ At wits end with battery? #31
A good battery will show ~14 volts when fully charged.
I personally never seen a battery testing 14 volts unless the engine is running, then I usually get between 13.5 to 14.5 volts. All my batteries that I have tested with engine stop and no load were around 12.5 V. My personal experience. :)
Three (3) John Deere 6000-Series Hood Guards (A63116)
Three (3) John...
2025 Swict 66in. Bucket Skid Steer Attachment (A61572)
2025 Swict 66in...
2012 MACK CHU (PINNACLE) (A63569)
2012 MACK CHU...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
Bobcat T66 Compact Track Loader (A64047)
Bobcat T66 Compact...
66'' BUCKET WITH TEETH (A61567)
66'' BUCKET WITH...
