Oil & Fuel 80w in hydraulic?
/ 80w in hydraulic? #1
mikeweber3
I have a Kubota B7100 Serial B71001-59209 Manual transmission tractor. The hydraulics share the the tranny and rear end oil. My owners manual says "Use Gear Oil SAE No. 80 or equivalent" This doesn't make sense to me. do you think it is correct?
/ 80w in hydraulic? #2
If you have a loader or any axillary hydraulics I would definitely use UHD. If not then use gear oil.
/ 80w in hydraulic? #6
Viscosity of 80W90 is not that far off UDT (I don't know if straight 80W is available anymore). It is about 15 cSt at 100ーC. UDT is about 9 - 10 cSt at 100ーC. At 40ー they are about 139 and 55. If you use UDT you are using a lighter weight oil than the gear lube although not by much, but you are losing the EP additives of gear oil. If your transmission needs the EP additives and you use an oil that doesn't have them, you will be looking at rapid wear and early failure. Unless you find out Kubota made a mistake in their manual, I would stick to their recommendation.
/ 80w in hydraulic?
Thanks to all
I think I'll do 89/90.
/ 80w in hydraulic? #8
There is not a modern tractor in use today that uses gear oil for hydraulics. Not one of mine uses gear oil, and they are putting 300hp through hypoid gears using transmission oil. Everybody can do as they please but if you don't want a sluggish loader I would use what Kubota uses now too.:thumbsup:
/ 80w in hydraulic? #9
If 7100 is like 6000 I had, manual gears and FEL used separate systems...OK to use gear oil in transaxle, 3PT designed for it. Hydraulic in FEL.
E-Z TRAIL 500 GRAIN CART (A64277)
E-Z TRAIL 500...
2016 PETEBILT 579 69 SLEEPER (A62613)
2016 PETEBILT 579...
2018 FORD F550 XL 6K LB SERVICE CRANE (A62613)
2018 FORD F550 XL...
2018 INTERNATIONAL LT625 DAY CAB W/ WETLINE (A62613)
2018 INTERNATIONAL...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
5' Bush Hog (A62613)
