Kioti new owner
/ Kioti new owner #1
kiotinewbe
kioti lb1914
Howdy, I am the new owner of a Kioti LB 1914, sn 04000623. Can someone tell me what year this is? How can I get an owners manual, or copies of the pages to understand the different levers and options. For a 20 hp tractor this seems to be "Heavy duty". Any suggestions about sources for oil/fuel/air filters or cross matches to other filter manufactures. Thanks for any information. DT
/ Kioti new owner #4
Welcome Kiotinewbe.
Their site describes it as an industrial machine.
KIOTI - run ahead of the pack!
What part of the world are you in? Someone probably knows of a local dealer that could answer all of those questions for you.
/ Kioti new owner #5
that's an older serial number. The newer ones start with 2 letters. Your best bet is to call any Kioti dealer and ask them, they can look it up. They can also get you any manuals you need.
I looked online (ebay) for manuals for my DK, and actually found that my dealer had a better price.
I did find this info for you
http://www.tractordata.com/farm-tractors/001/5/3/1531-kioti-lb1914.html
and they list some serial number with years made. But i dont see any numbers like yours. They state that the number is on the transmission housing ahead of the clutch pedal.
/ Kioti new owner
Thanks for several replys and the link to Tractor data. I am located east of Portland Oregon, in Suburbia. Evidently the closest dealer is in Longview Wa. I was able to call the Kioti Main Office, and evidently the new numbering has one more number in front of the 04. I think this is an 1988.
Maybe one more question, This is a 3 cyl. and there is a gasket leak under the plate that the 3 injector lines fasten to. I take it that the injector pump is driven off of the flywheel at the back of the engine.
The question, is there an easy way to take that plate off without taking off the manifold on the right side of the engine? Can I make a gasket or am I better off buying one from a dealer?
It's nice to find several of these around and a group of loyal supportive owners. Thanks, dt
/ Kioti new owner #7
Boy, thats way beyond me. Id have to get a look at a service manual for that engine to answer that.
/ Kioti new owner #8
Welcome to TBN.:thumbsup:
Slow down a little and give yourself and us some time for more owner's of the same tractor to read your post.
If you want best response to a question post it separately so it has a title pertaining to your issue.
How much is the plate leaking? What is it leaking? Are there bolts you can snug up with a little careful wrenching?
How many hours on the clock?
What are you going to be using the tractor for?
2017 Mitsubishi Fuso FEC72S Landscape Truck, VIN # JL6BNH1A9HK003132 (A65563)
2017 Mitsubishi...
PALLET FORK MOUNT SAFETY BASKET (A61572)
PALLET FORK MOUNT...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
2022 EZ-GO ELITE...
Landhonor Quick Attach Adjustable Hydraulic Pallet Forks (A66408)
Landhonor Quick...
