HST Fluid
/ HST Fluid #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
/ HST Fluid #2
Shell Donax TD [ one of the approved oils for the 5035 HST ] is now called Shell SPIRAX S4 TXM...
SHELL DONAX TD - Buy Online Now! SHELL DONAX TD Usually Ships Sam ...
just in case you go into your local Wally to look for it....... [ don't have a cow ]
Jerry,
Don't you just love to understand names and then they are changed.:shocked: Here is a chart of all the new names.:rolleyes:
http://www-static.shell.com/static/...s/shell_complete_products_transition_tool.pdf
Thanks for the heads up.;)
hugs, Brandi
/ HST Fluid
/ HST Fluid #4
Heh, thanks for the chart..!!! Navigating the various different HST fluids is bad enough without the manufactures changing the names... Makes motor oil discussions mild in comparison.... :)
Jerry,
Hey, anything for a tractor brother.:D
hugs, Brandi
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
2025 Kearney 7'X20' (A62177)
2025 Kearney...
