Oil & Fuel 2320 50 Hour Service
/ 2320 50 Hour Service #1
lipps1948
I recently changed my Hydro oil & filter, but could not find the magnets located at the inside transmisson filter, have they quit installing these magnets. :confused:
/ 2320 50 Hour Service #2
Attached inside of drain plug inside may have a magnet.
/ 2320 50 Hour Service #3
Mine had the magnets inside the strainer behind the 3pt sway chains.
I also just did the 50 hr service on mine and it wasn't too difficult other than having to take off the left rear tire(fluid filled!) to get the pin out enough to get the sway linkage out of the way! It was also interesting trying to get the filters broke loose, it was like they were tightened by a bodybuilder gorilla!
/ 2320 50 Hour Service #4
Hey lipps. Welcome to TBN:)
Jd parts shows the magnets inside the strainer. They are #16. If yours doesn't have them,I would get them pronto.They are a critical part of the transmission filtering system.
Greg
/ 2320 50 Hour Service #5
Scrappy, you don't have to take the wheel off if you remove the bushing into which the pin goes that holds the sway linkage. The bushing on the left is removed with two bolts. The one on the right has three bolts -- I remove the one on the left.
/ 2320 50 Hour Service #6
Yeah, the xmission filter was tight the first time. I use a standard, adjustable engine oil filter band clamp and it loosens the xmission filter easily.
/ 2320 50 Hour Service #7
As GLC mentioned, you really do want those magnets. Mine have caught a lot of fine metal pieces that have otherwise gone through the filter screen.
Thanks, you guys for helping out, really enjoying being here on site....:thumbsup:
/ 2320 50 Hour Service #9
Thanks! I didn't even think of that, but I will try to remember that tidbit for next time!
/ 2320 50 Hour Service #10
Scrappy its about time you got some hours on that machine. :) Hope things are going well for you.
/ 2320 50 Hour Service #11
Doin' good! wish I had more to do to put more hours on it! I keep looking for more stuff to do but everything is putting a damper on that!
/ 2320 50 Hour Service #12
I'm to lazy  i just had my local dealer do mine! I need to hang out hear more and learn!!!
2021 UTILITY VS2DX 53FT DRY VAN (A59905)
2021 UTILITY VS2DX...
John Deere 50 (A60462)
Freightliner Cascadia (A63689)
Freightliner...
JOHN DEERE 460M SILAGE BALER (A63291)
JOHN DEERE 460M...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 82349 Pla... (A59231)
Year: 2017 Make...
2016 Freightliner 114SD T/A Vacuum Truck (A61573)
2016 Freightliner...
