Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Guess I would side with the group that says replace with a factory cord. They available and not that over priced. No question the safest way to go. If it is a tool you have to keep, that is going to be the best and safest solution.
no question? please....
you have 2 things to deal with in a cord replacement.
1, materials
2, technique
lets look at safety from both perspectives.
materials. I can go buy UL listed insulated cord in bulk.. I can buy ul listed replacement plugs.. both are 'safe' when used correctly.
technique. Since replacement with either a home brew cord or the factory original is going to involve opening the tool and removing whatever conenctor method has been used.. it all falls down to opeerator capability. Over the years I've found the following conenction methods:
1, solder.. IE.. the wire enters thru the strain relief or grommet or otherwise thru the blukhead of the tool and one side is soldered to a switch, adn the other to the motor, etc. in places where a ground wire is used, it is either attached to atab on the case.. or for a plastic tool, I have seen them go right to the motor.
2, wire nut/scotchlock as above.. wire enters, and has mini wire nuts to attach to internal pigtail stub ends.
3, crimp-wire nuts, as above but wire nut is a nylon insulated crimp collar.. usually cheapest way.. generally have to cut them out, meaing you are shortening the oem wire stub in the tool.
If the operator is not up to par.. then there is going to be -NO- safety difference with using an oem cable, vs a replacement. it's a connection making exercise. either you can do it.. or you can't.. if the repalcement material is correct.. it should be the same deal as the oem.
4, oem molex or similar connector, VERY RARE, only in a few very rare cases have I opened a tool and seen a molded slip together connector. still.. takes a lil more work.. but you can repalce those too. the molex are generally crimp.. some are solder pins.. slip pins out with release tabs, change connector over to new wire and go. this repair takes more time with a non oem cord thant he rest of them. still... usually saves even more money as an oem cord repalcement with a specialty molded connector ain't gonna be as cheap as a pigtail whip style..
thus.. safety is left almost completely up to operate capability without reguard to oem replacement or generic repalcement parts. use safe parts, and the balls in the court of the 'replacer'
If you are just trying to resurrect a relic, tools are really inexpensive right now and are much superior to those that have lived a decade or better. Just my opinion.
MarkV
tools now superior to an older tool? that's a very supjective statement.
I like the 'inexpensive' new tools available like the next guy. I buy quite a few at harbor freight for applications I don't want a nicer tool in. for instance.. I have a NICE makita angle grinder. I also keep a couple 9$ harbor freight specials for doing 'junk' work where I don't want my makita to get beat or banged up. especially if I'm doing alot of welding and I don't want all the lil weld pop and spatters dimpling the pretty blue plastic on my good grinder.. but I DO want a grinder laying right next to me so i can snatch it up and grind when needed.
looking at the innards of a 9$ tool and a 69$ tool.
I have plenty of examples. I have a nice sears radial arm saw from the 70's, and I have a good skill saw from the early 90's both are superior to 'cheap' ones I have used new. I have a 'cheap' table saw that I used for very infrequent jobs. the skillsaw / RAS I have have smaller motors yet handle loads WAY better than that cheap-o table saw.
very few cases where a inexpensive new tool is going to be higher quality than a good proven tool that is a lil older.
same with hand tools. Again.. i like the 9$ wrench sets and 5$ ratchet sets harbor freight sells.. again.. good and easy to toss into a tractor tool box.. don't care much if it gets stolen or I loose one.. or have to torch and bend a wrench that cost me 20 cents. however.. they just don't compair tot he quality of some of the good tools I have from 10-20-30 ys ago.. I have a nice sk 1/4dr socket set in a metal container. way higher quality than the 2.99 HF special 1/4 drive kit that has the lil plastic socket holder. i've also stripped out a couple pakistani socket wrenches before.. no biggie.. i buy socket sets at flea markets and yard sales for a buck... I use them for junk work.. working in the dirt.. etc.. or again.. if i have to torch a tool. cheap stuff has it's place. does it work.. sure.. in most applications.. as good int he short term even.. is it better than a real quality tool that might cost 3-4x as much 9 some of that cost just paying for a name.. some for the quality.e tc.. )? please....
and that's not my opinion... that's observed fact from years of good and cheap tool owning and using.
soundguy
