Traction BX2660 Towing capacity
   / BX2660 Towing capacity #1
jimbog
Kubota bx2660
I have seen on some forums the statement of the bx26' You will run out of traction before you run out of power'.
I use my bx2660 (Turf tires) to move around my 20ft cape island fisher (on a 4 wheel trailer). I have trouble pulling the boat up my ramp (quite shallow incline).
I can back her down and stop her comfortably but pulling back up... no go.
I tried increase revs to near max but no movement and I am afraid I will damage something trying (so stop!).
But the wheels definitely dont lose traction or spin. It will move it around on the flat no problem. I dont know how much the boat and trailer weigh, but its quite a heavy 20footer, i would have thought 3-4000lbs max! and yes, the wheels on the trailor are nice and free.
I just assumed its too much of a job for it. Am I right?
I currently use a 3500lb winch (cable doubled) fitted to the tow bar to pull it up, no problem.
   / BX2660 Towing capacity #2
In "turtle"? I am surprised it doesn't move or the tires don't spin, frankly. One or the other. I am also a bit surprised a 20' boat and double axle trailer doesn't weight a bit more then you are estimating. Hmmmm. I don't know.
You also have to figure the BX is up against the water resistance and an incline, so it likely is asking too much of it.
   / BX2660 Towing capacity #3
There should be a towing spec in your manual for the tractor.
I don't have a bx tractor, but FWIW, my L3700su is 2200 lbs max trailer load (730lbs tongue weight). This number seems conservative to me.
   / BX2660 Towing capacity #5
If you run out of power the RPM's will fall. If you run out of traction the tires will spin. What did yours do?/
I would be extremely surprised if it weighed more but you could be right. I put it on the trailer at high water and pull it out and low, so the boat and trailor are out of the water.
I havent pulled it out since last october, just put it in and left it in so I am working off memory, but I would say it just whines from the back, cant remember if the revs dropped. (I had it from new and it has less than 150 hrs)
Just read the manual (who reads those things!)
Max load 1765lbs, so looks like I should not expect it to pull the boat.
I was just intrigued by the statement 'lose traction first' .
   / BX2660 Towing capacity #8
1. You are using LOW (turtle) range, right? If it's in HIGH (rabbit) range, no, you wouldn't be able to spin the wheels.
2. Concrete boat ramp or ??? The horsepower vs. traction thing usually relates to open ground, being that it's a tractor and all. Wouldn't expect a tractor to spin its tires on pavement (dry or wet).
3. Similarly, a 4000lb boat may put so much weight on the back of the tractor that its rear tires couldn't break loose and spin.
You are putting the HST into relief, so it won't bog the engine. But, instead of burning something up, a relief valve is triggered and the wheels don't turn.
   / BX2660 Towing capacity #9
Losing traction is very easy. Just be in dirt or pull a box blade, middle buster or other things such as that and the wheels will easily spin.
It may be that the boat ramp provides good grip and the boat is so heavy and the resistance so great that the HST indeed, just bypasses to protect itself.
I've pulled 3000 lbs very, very slowly with my BX, in Turtle, on level ground, and not very far, back in the day, but it was all it could do. Of course, it wasn't uphill and it wasn't with the trailer wheels down in a lake. :)
   / BX2660 Towing capacity #10
I would be suprised if your boat and trailer were not heavier than you think. I had a 17' fiberglass bow rider with a single axle trailer and it was over 4000lbs. (I realize this in no way solves your problem)
Matt.
Skid Steer Sweeper (New/Unused) (A59225)
Skid Steer Sweeper...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
17102 (A56859)
17102 (A56859)
2016 Fiat 500X AWD Hatchback (A56859)
2016 Fiat 500X AWD...
SULLIVAN PATEK AIR COMPRESSOR (A58214)
SULLIVAN PATEK AIR...
