Howse Disc Question
   / Howse Disc Question #1
lakngulf
Lake Martin Alabama
Kioti CK30
I have a 66in Howse Disc and a question about how tight each connection should be--a picture of one similar to mine is included below.
My question is about some bolts that connect the upper frame to the plow section. On my disc the U bolts in the front of the picture are good and tight, but the U bolts that hold the bars that hold the series of four or five discs is not tight. After plowing I checked the nuts on these connections and they seem to be lock nuts, but not run up the thread very far. I tried to turn them a bit but very difficult
Should these be tight or it is best for the bars to swing a bit? They appear very tight in this picture.
   / Howse Disc Question #2
They should be tight,and I'd have to dig out my manual to see if they should be "torqued" which I don't think so,but not really sure.
Boone
   / Howse Disc Question #3
Milton :
I dug out my Howse disc harrow operators manual.They do have to be"tight".
Also it has a torque / bolt specification chart.I will just make sure mine are tight not going to be checking each nut bolt with a torque bar.
Hope it helps ! :thumbsup:
Boone
Milton : I dug out my Howse disc harrow operators manual.They do have to be"tight". Also it has a torque / bolt specification chart.I will just make sure mine are tight not going to be checking each nut bolt with a torque bar.
Hope it helps ! Boone
Thanks, Boone, for the research and info. Mine actually has a set of U bolts in addition to the ones in your picture, but I do think these need to be tighter than they are also. In your picture the bar the holds the U bolts that hold the discs is positioned between two pieces of metal welded on top and bottom of the slot. On my disc the bar is attached with the U bolt.
It looks like there may be some play in the slot on your disc, and it may be ok for mine to have some play as well. I know the U bolt that holds the disc needs to be extra tight.
Thanks for your help. I tried to tighten them a bit before plowing yesterday afternoon but found that I need two 3/4 wrenches to make it happen. The old adjustable wrench just does not hold in some cases.
Harlo HP6500 (A60462)
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
1994 Chevy 2500 Pick Up (A59814)
1994 Chevy 2500...
2018 Ford F-350 (A55973)
2018 Ford F-350...
Volvo EC220EL (A60462)
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
