YM336D Restoration thread - Part two
/ YM336D Restoration thread - Part two #21
Nice job Domush!
I wonder if you can find a laser engraving place to do the Yanmar I have seen some pretty intricate things made with lasers on wood?
Big update today!
I am 99.5% finished the beautification and I must say.. you should really stop reading this crap and look at the pictures!. Where is a tractor parade when I need one?!
Without further ado.. the before and afters..
TO:
And the during..
Here I test fit the gauges, which fit perfectly. The black really brings out the wood color.
After painting the entire tractor, including the engine, I threw on a full coat of clear which I happened to have hanging around from a cancelled boat restoration. Wait until you see the difference the clear made.. (I hope you can tell through photos)
The hood with a clearcoat
The dash is finally installed! This is right before I got down to the wiring, which took FOREVER. Man, added lighted gauges adds a TON of new wiring; The wiring was crazy enough with all of the missing switches and cut wires this tractor had.
Time for some brackets for the new headlights. These are simple aluminum sheets bent 90 degrees and some holes drilled for mounting bolts. I have no idea where you can find sheets of aluminum.. a neighbor happens to own a metal shop so I get to raid his scrap bin. Before meeting him, I have no idea where I'd get sheet aluminum.
When I originally cut the headlight holes, I knew extra space was needed in case I had to adjust the aim of the headlights, so I cut the hole bigger. I added weatherstripping to the inside of the hole in order to create a seal around the lights themselves.
The resulting assembly.
And the result of all of my hard work! All of these crappy posts have been, indeed, leading to something after all!
Exact before and after shots
The completed dash. Note the 1/off/2 toggle switch. Set to 1, the headlights only come on while the key is on. Set to 2 will bypass the switch, in case the tractor is off or I don't have the key handy. All switches are lighted, of course.
I moved the key switch to the bottom panel, as there is no reason for it to be always visible. It also seems more natural to turn the key where it is now.
Close up of the wood lights and trim.
Showing it off at my neighbor's house, haha!
Dash while the engine is running. I have a bit of an anti-freeze leak after removing the thermostat I need to seal up and a coat of paint on the steering wheel is still pending, but otherwise she's a done deal for now.
Parked in my visitor parking spot in the driveway. Her new home will be elsewhere, but I wanted to be able to stare at it a few moments more, heh.
Hope you all enjoyed following along for this restore. I certainly loved sharing my experience with all of you. Let me know what you think. I love it so much I hated putting a footprint on the newly painted footrests! I really am waiting for the next parade. This thing is cruising in it for sure! I can even use the post on the canopy to hold a flag! I need an aoooooga! horn, now :eek:
/ YM336D Restoration thread - Part two #24
Wow, Great job! That thing looks good. I especially like the wood. I'll need to remember that when I get a tractor new enough for gauges. It sure is a beauty and night and day from how it started. I just stumbled across your threads a couple of weeks ago.:thumbsup: I hope you get it 100% completed soon (isn't there something wrong with a few gears in the tranny if I remember right?)
Cheers.
/ YM336D Restoration thread - Part two #25
Very nice work, my 336d has a cream/white rim color but the red is nice.
/ YM336D Restoration thread - Part two #26
I think he knows that. They also have green engines and lift arms and trannies dont they, at least the greys do. They also dont have any wood on them, but this is his custom/resto.
/ YM336D Restoration thread - Part two #27
And he did a great job on it. :thumbsup: Seriously, nice job on that 336D, only thing I would change is paint the "YM336D" emblem on either side black with white letters but this is just a suggestion. :) Either way, excellent job on the restoration. :thumbsup::thumbsup:
Yeah, I plan to paint the circular emblems at some point. I haven't decided the best method to do it accurately yet. For now, though, I have a box blade on it already and can smooth out those blasted pot holes in my driveway (really long dirt driveway). A neighbor has offered for me to borrow any attachment he has, which I'm thrilled about. His attachments are 6'+ wide, but I should be able to make do for now. I only wish I could power the 12' batwing finish mower he has :D.
I have a large web project happening now, but hopefully in the next week I can lift that shift cover off and see what the 1st and 2nd gears look like. I also notice a clunk every few seconds while the clutch is out (even when standing still), which I have yet to diagnose. It sounds as though it is coming from the rear end, but I'm not positive.
For now I have a propane tank to sandblast and install and a web site to build to pay for all of this outgo :)
/ YM336D Restoration thread - Part two #29
Beautiful job. I'd never have the patience for something like that even if I had the talent (which I don't have:eek:).
/ YM336D Restoration thread - Part two #30
That tractor is almost too nice to use. You did an excellent job.
After doing some box blade and boom pole work with my restored 336D, I finally got around to pulling the transmission cover to see what I'm up against in terms of the non-working 1st and 2nd gears.
The teeth on the counter gears are pretty much gone. The main gears seem oddly unaffected.
I'll have to split the tractor in order to gain access to them for repair or replacement, which will be a major first. I'm not thrilled about draining the transmission fluid yet again.
I called Hoye and a new counter gear assembly (they don't sell them as individual gears :() costs a whopping $1500 :shocked:, more than I paid for the entire tractor!
So, what I'll end up doing is welding some more steel on each gear tooth and grinding them back into shape. Whether or not I can successfully do this.. I'm guessing my odds are 30:70. If I just can't seem to get it right, I'll pay a machine shop to do the grinding.
Let the tractor split begin! :confused2:
/ YM336D Restoration thread - Part two #32
Anychance of welding them in position ? I had a reapir done one time on a john deere, the welder came to the farm and welded up two spots for me that worked perfect,I still dont know how he could see or weld the spot he was working in. Just a thought as if it doesnt work the worst you'll have to do is split the tractor ....
/ YM336D Restoration thread - Part two #33
Hoye has a few parts tractors, i guess they dont have one of those do they or else they would have said so.
/ YM336D Restoration thread - Part two #34
how does damage like that occur?
/ YM336D Restoration thread - Part two #36
Thanks Car Doc :laughing::laughing::laughing:.
Let me ask this another way.....What would have had to happen to cause this damage - so I know NOT TO DO IT!
/ YM336D Restoration thread - Part two #37
How about one tooth breaking and becoming that stray part. Could happen when someone grinds the gears, maybe when the tractor is still moving a little. I have been guilty and don't like the sound it makes. :)
/ YM336D Restoration thread - Part two #38
The reason I ask is that I was thinking.....if a tooth breaks off it might get caught and do some damage but then fall into the bottom of the pan???? this took out two sets of gears and didn't touch the other two. I would think this scenario made one heck of a racket
/ YM336D Restoration thread - Part two #39
Tooth bit A falls into first gear destroying it and causing a tooth B chip to fly over to the second gear destroying it as well. Just a thought?
/ YM336D Restoration thread - Part two #40
I would think it would be pretty hard to break anything in our tranys guys with normal use.
But remember he had that 4wd shift dog that got loose in there and that may well have been what grenaded the gears and there were a big handful of other various things floating around in there too any one could be the culprit and they can also wedge between the gear set and the case and only damage the one shafts gears he did say the counter was the one that was damaged the worst its the bottom shaft. :)
Kubota Snow plow with subframe
Kubota Snow plow...
2004 Winnebago Adventurer 38G 38ft. Class A Motorhome (A59231)
2004 Winnebago...
2019 CRUISE CAR INC ENCLOSED UTILITY CARGO CAR (A59912)
2019 CRUISE CAR...
Caterpillar M318 Excavator Service Manuals vol. 1 and vol. 2 (A63117)
Caterpillar M318...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
