Skid Steer attachment for tractor Loader
/ Skid Steer attachment for tractor Loader #1
mitchash
Gold Member
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
Anyone know where to buy or how to build a skid steer quick attach system for a tractor loader? Thanks
Anyone know roughly the prices for plates (tractor side) already built?
/ Skid Steer attachment for tractor Loader #5
You can get info on the standard dimensions for SSQAs here
Universal Attachment Plates : Skid Steer Attachments : Quick Attach Attachments, Inc.
Here's the SSQA on my 2008 Mahindra 5525--cost ~$900 installed
DSCF0110 (Small).JPGDSCF0111 (Small).JPGDSCF0112 (Small).JPGDSCF0181 (Small).JPGDSCF0182 (Small).JPG
The spring loaded retention pins look like the most complex part of the assembly and they are important--you don't want your FEL bucket coming detached while hauling a load (don't ask how I know:confused:).
Good luck
/ Skid Steer attachment for tractor Loader #6
Depends on what your putting it on. What size of loader. I just bought one from Bobcat for my CT225 is was $400 but the one for the bigger CT400 models is closer to $800.
Im looking on buying a loader from Coldwater for my Jinma 25hp 4x4 tractor. I think it will lift around 1000#. I also have a Bobcat 753 skidsteer that I want to share the attachments between the two machines.
I have a Coldwater loader on my Jinma 254. It has just one tilt cylinder in the middle. I have been looking at making it a quick attach so I can use my skidsteer forks and tooth bucket. I haven't found anything that was made for this loader but have found some that you can build your own. One was from SkidSteerAdapter.com Any others I should look into? Thanks, Ash
/ Skid Steer attachment for tractor Loader #9
I just built one last wk to go on my brothers 4610 ford. I had a factory attachment off another tractor that had gotten warped up by the previous owner. the two sides where connected with a 2 1/2 in sq tube. At first we thought we would just cut out the old tube and replace it, but the width of his tractor forks was wider than a standard skidsteer quick attach mount so it wasnt a matter of just replaceing the tube and rewelding. The new standard for a quick attach is a width of 44inches, outside to outside of the mounting plate. His forks where 48 inches. What I did was take a piece of 3/8 plated, 48"x20". I also used 4 pieces of 3/8, 20"x4" to make the mounts for the fork and cylinder pins. I drilled out the pin holes and welded bushings to the outside of the plates for extra pin support. These brackets I then welded to the back of the 20x4 in plate. I then removed the tube from the quick attach and cut the mounting plates down to square it up on the new backing plate. It was then a simple matter of just welding the quick attach plates at the proper 44in width to the new mounting plate. I didnt take any pics. Since my brother doesnt have a quick attach bucket for his new hitch, he hasnt installed the new one on his tractor yet, I might be able to get a pic later today. After building this new adapter, and looking at the finished product, I think we could have saved some money by just buying enough metal to mount each side of the quick attach seperately and then reconnect with a piece of square tube. This would have made the quickattach lighter and we could have saved a few bucks, but it is what it is.
/ Skid Steer attachment for tractor Loader #10
I had one of these from Hayspear.com on a Kubota B3030 with LA403 loader. It did whatever I needed it to do.
Side to side adjustable for various width lift arms.
I bought the Thor Attachment ( Welcome to ThorAttachments.com ) latch boxes and will build my own frame to fit my tractor. They look to be very well built!
/ Skid Steer attachment for tractor Loader #12
I got the thor unit also. Just the boxes like you said - was around 450 if I remember correctly (this past summer). I cut the mounting brackets from my bucket and welded them to the boxes and painted. Here is a couple pictures and a video of it in action. http://youtu.be/vhjJTKPlMRk
I have not been gentle with it at all and it seems to be just fine - I don't even think about it any more - it is just another part of the tractor.
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
2016 Dodge Charger Sedan (A64557)
2016 Dodge Charger...
2012 Ford F350 (A62679)
2012 Ford F350...
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
2018 Freightliner M2 106 Elgin Broom Bear Street Sweeper Truck (A64556)
2018 Freightliner...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
