Problems with my Ford F-150
/ Problems with my Ford F-150 #41
MossflowerWoods said:
This was the local mecanic shop.
He said I may need to bite the bullet and visit the Dealer an shell out the $100 for a diagnosis because they can read deeper level codes than he can.
This truck as given me NO PROBLEMS until now.
David
Ask them to do the indepth analysis, but they are NOT to repair it. Specify that on the work order.
/ Problems with my Ford F-150 #42
Soundguy said:
hmm.. havn't had to deal with a COP issue.. but am converting just about everything newer I have to diesel as fast as I can.. anything I have that is gas, eventually, will be an antique tractor.. :) No COP.. only points.... :)
soundguy
My go DMAX next time too. You still searching for the 7.3L Truck that you posted about a couple of weeks back??
/ Problems with my Ford F-150 #45
Glad you got it fixed!
Just an FYI for someone, but you can check the TPS pretty easy with an analogue voltmeter. Back probe to get the ground and signal return and slowly move the throttle all the way thru its motion. The analogue meter's gauge will sweep smoothly between approx 1-5 volts (on ford's anyway). If the needle gets herky jerky or bounces around you have a bad TPS.
sld,
That is AWESOME Advice! I will remember that!:thumbsup:
Thanks,
David
/ Problems with my Ford F-150 #47
Wait til you try to replace the plugs on this motor. The Triton 3 valve motor plugs break off in the hole leaving a piece that needs to be extracted with a special tool. If all goes well its about a half hour a hole. If all does not go well.....
2019 AUTOCAR XPEDITOR TRASH COMPACTOR TRUCK (A63276)
2019 AUTOCAR...
2019 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2019 PETERBILT 579...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2000 Sterling Rollback L9500 Series Truck, VIN # 2FZNEWEB1YAG12895 (A65563)
2000 Sterling...
2015 Chevrolet Silverado 2500 (A62613)
2015 Chevrolet...
20ft Driveway Gates (A65579)
20ft Driveway...
