Cruise control in reverse
/ Cruise control in reverse #1
kiotimiike
Member
New Brunswick ,Canada
2011 DK45SE cab
I have a 800' driveway and would like to be able to use my cruise control when in reverse while snowblowing.Has anyone figured out how to get this to work?Is this possible?
/ Cruise control in reverse #2
I don't believe it would be possible to do this unless you design something completely different. The cruise control works through a magnet on the forward HST pedal whose arm is adjacent to the magnet. The reverse pedal arm is too far away from the magnet to be controlled by it and when in reverse the forward pedal is not lined up with the magnet.
I suppose one possibility might be to weld a plate on the forward pedal that is over the magnet even when the reverse pedal is activated. I think you would also need to modify the control circuit that activates the magnet. Likely not worth the trouble.
/ Cruise control in reverse #3
To do this feat of engineering you must remove the engine and transmission and install them backwards to the usual way they face. You may want to put the seat on a total swivel too.:D:laughing:
/ Cruise control in reverse #4
Great! :thumbsup::laughing:
/ Cruise control in reverse #5
Or just use a brick:)
/ Cruise control in reverse #6
/ Cruise control in reverse #9
Don't own a kioti but the last new Holland I had tc33d the cruise worked in reverse as well as forward
/ Cruise control in reverse #10
Mike, when running my boxblade in reverse, it just seems hard to maintain the correct track going around curves. If your driveway is crooked or covered in snow, it seems likely you will find yourself going off the road a lot and having to stop and correct your direction and position. I don't know if you've tried driving the whole way in reverse or not, but I'd give it a try just to be sure the effort to convert your tractor is worth it.
/ Cruise control in reverse #11
the electromagnet is placed on the forward HST peddle ONLY. Wont work in reverse on my DK45HST
/ Cruise control in reverse #12
why would you use cruise control blowing snow.... you really shouldn't use it any time there is a chance of running into anything. I have co-workers who will drive the company truck with the cruise control buttons, in traffic. It makes me insane.
/ Cruise control in reverse #13
It would probably be simpler to obtain the modification kit to mount your snowblower on the front. Of course, if you have a blade on the front like I do, this isn't such a viable option.
Alternatively, you could move to somewhere where this isn't any snowfall...that would work too.
Jon
(15) UNUSED 3 1/2' X 8' PLASTIC PROTECTION MATS (A64281)
(15) UNUSED 3 1/2'...
2001 Mack RD688S T/A Galbreath Roll Off Truck (A61573)
2001 Mack RD688S...
2002 Suncoast 18ft T/A Enclosed Trailer (A61574)
2002 Suncoast 18ft...
2018 TAKEUCHI TL8 SKID STEER (A64279)
2018 TAKEUCHI TL8...
CHEVROLET C-40 FLATBED TRUCK (A63291)
CHEVROLET C-40...
UNUSED WOLVERINE 7' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
