Front-End Loader How does a FEL rate for grading a driveway?
   / How does a FEL rate for grading a driveway? #41
Another thing - and I may be all wet here, but it seems to me that a box blade can be self defeating when trying to cut a hard surface unless the rear blade is hindged. If the rear blade is fixed when you try to tip the box blade back to get a better cutting angle of attack on the front blade it rolls up on the rear blade and lifts the front blade so you loose more than you gain. If you tip the box bade forward so the rear blade does not impede the cut you are stuck with a steep angle of attack which might bounce and not cut very well. Most grading scrapers I have seen have there blades set at a shallower angle than you can get with a box blade when the rear blade is fixed.
Now in dirt or soft material none of this matters but from my experience trying to cut a hard surface works much better with a shallower angle. The blade angle of attack on my scraper is a little over 45*.
   / How does a FEL rate for grading a driveway? #42
I am fairly sure that you would find that the people who have LPGBs have all but forgotten about their box blades when it comes to their roads and driveways.
That's me :thumbsup: Poor box blade just sits there now :eek:
Some things I can think where a box blade excels:
1) Digging a hole. The skids on the sides of a grading scraper would make it take longer to dig a hole because you'd usually be able to remove a shallower slice of material with each pass. With a box blade you should be able to lower it further & dig more per pass. This of course is not something you normally want to do when maintaining a road/ driveway. However, you could adjust the grading scraper's blades down so they dig deeper with each pass.
2) Pulling a load of material where none (less anyway) spills out the back while dragging. A grading scraper is designed/ intended for material to flow over the two blades to smooth out the surface, fill in holes, etc. You may not be able to drag a full load of material without some of it flowing over the blades, & then you'd have to get it on your next trip instead - The box blade probably usually holds the full amount for the whole trip?
3) The box blade is shorter front-to-back. Good for maneuvering. Not good for overall implement weight, if max weight is what you need.
All that said, I don't see me using the box blade again. Probably ever. The grading scraper is just the ticket for me.
   / How does a FEL rate for grading a driveway? #43
One of the big pluses to a roll-over box blade. You don't have these problems. ;) But I think that pretty much everyone has discontinued building them, so the hinged rear blade box blades are probably the best bet now days.
   / How does a FEL rate for grading a driveway? #44
Fel's are not the tool to use on a driveway most of the time, here are a couple of pics of the driveway grader I built for around 60 bucks. Works great for me. Just drag and it lifts up the gravel and the fines, cuts the grass crown off, and fill the pot holes.
   / How does a FEL rate for grading a driveway? #45
I have a Cammond Grading Scraper that does a wonderful job on my road. The thing I have noticed is that the "churn" between the two cutting blades tends to leave the larger gravel nearer the top and the fines further down. I would rather have a more evenly distributed fines and larger gravel (1.25 inch minus.) Is there a technique that will help this? I wondered if my cutting edges need to be lowered or raised from where they are set (Adjustable from 0-1 1/2" below side plates) in order to effect the distribution I want.Any ideas from you experts?
You didn't say where your blades are set but I would say they need to be at least as deep as the biggest material on the road surface. Other wise your grader can just roll along on top without pulling up the fines underneath for a good mix.
Don't consider me an expert - just opinionated
   / How does a FEL rate for grading a driveway? #46
Looking to knock the crown down and level up some washed out areas with a near-future purchase (compact). Can the FEL loader do it moving forward or would it dig in too much? Drag it angled down and backward? Just trying to assess the FULL cost of what it's going to take to get things done around here in terms of tractor/implements/attachments. :confused:
I wouldn't say it can't be done but, it is not the most efficient way to do it.
I have a 3pt. rake and rear blade and a FEL. I use them all when I do my gravel drive.
I have come to like back dragging with the bucket. I can "feather" it better than whatever is on the 3pt. hitch. And, the FEL has down pressure. Not a bad thing.
   / How does a FEL rate for grading a driveway? #47
Anyone ever try to make some heavy skis to bolt on to the sides of your existing box blade? Maybe with a 2nd angled blade that ties them together behind the box blade? This would essentially turn a box blade into a land plane on the cheap if you have some fab skills. Maybe I will give it a shot when i get around to buying a box blade.
   / How does a FEL rate for grading a driveway? #48
I'm new around here. Just bought my first tractor. Kubota B7200. My driveway is about 150 ft of gravel and hard ground underneath. I graded it today with the loader on the B7200. Had to cut down the crown which also had weeds and level it and move gravel. Tractor worked fine. I've done it before with FEL larger tractors. Doing it is no problem but it takes a lot of time. I'm gonna get a Box Cutter or at least a blade before I do it again next year... :)
   / How does a FEL rate for grading a driveway? #49
I grade my drive with the fel with a ratchet rake on it. Add a rear blade to the mix as well. Does a great job.
Funny you mention the ratchet rake. I've been eyeballing them for clearing up the woods here at the compound. For $300, I might see if I can round up some HD angle iron and have another welding project. :)
2007 Chevrolet Silverado 1500 (A55973)
2007 Chevrolet...
UNUSED FUTURE RB66-66" ROCK BUCKET (A57193)
UNUSED FUTURE...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
30088 (A55853)
30088 (A55853)
2021 CASE IH 345 LOT NUMBER 12 (A53084)
2021 CASE IH 345...
2022 CATERPILLAR 289D3 SKID STEER (A52707)
2022 CATERPILLAR...
