CIH 5230 loader valve
/ CIH 5230 loader valve #1
HHelms
CaseIH 5230
Hey Guys
New guy here.
I recently purchased a CaseIH 5230 with a Koyker 500 loader, which uses the remotes.
I would like to replumb with a 2 or 3 spool cable/elec operated joystick loader valve, so that I can use my remotes when I need them. I have the power beyond plate, but am not having any luck finding the proper loader valve. The valve needs to be compatable with the Beyond power, pfc, remote sensing, hydraulic system.
Thanks
H
Thanks JJ.
I probably should have included more information on the tractor system. Its a closed system, 20 gpm, Bp, sense line, pfc system. It seems like a pretty complex system, and I was hoping someone had already done a valve retorfit and could help with reference, or valve numbers.
That valve might work, but it is open center and max flow is less than the 20 gpm. I really have no idea if it is compatable with or not. It appears to me that the pb plate basically taps into the hyd system and bypasses the priority of the remote spools.
I called Surplus center last week and they indicated that part # 97676 might work, but I hate to spend the money on a "might work" valve.
As you can see confusion abounds.
H
/ CIH 5230 loader valve #4
/ CIH 5230 loader valve #5
The PFC hydraulic is what I'd call an advanced closed system.
/ CIH 5230 loader valve #7
Tractor dara says closed cented, but where did you get the Power Beyond stuff. It is usually associated with open center hyd system.
This one below is a 25 GPM loader valve, and can be converted to closed center.
Surplus Center - 2 SPOOL 25 GPM JOYSTICK LOADER CONTROL VALVE
This is the valve you referenced, and it is CC, and the max pressure on this valve is 2610 psi max, and GPM's is 17.2 .
Surplus Center - 3 SPOOL 17 GPM BONDIOLI PAVESI CC LS VALVE
The first valve linked here is totally inappropriate for a PFC/CCLS system, the second one looks like a great value and would work well.
JJ
The owners manual references the power beyond plate for: " when a continous supply of oil is needed eg, front loader. The return port can be used separately. The implement must be fitted with a closed center valve"
From what i can tell its just a plate that sits on top of the remote spools and gets first priority on the oil. ??? It was quite expensive for a 1/2 inch cast iorn plate that only had about 10 minutes of machine work involved.
H
RickB
Thanks for the info.
Are the Bondioli valves good valves?
H
/ CIH 5230 loader valve #10
RickB
H
I don't know anything about them. But it would not be hard to spend 4 times that price on a valve with similar capabilities and capacity. Having the built in ability to control a grapple or other 3rd function via the solenoid controlled spool is a neat plus.
Rick
I hear that the hydraulics on these tractors are pretty slow, even at 20 gpm.
Do you think the 17 gpm bondi valve has enough flow rate to operate the loader?
H
/ CIH 5230 loader valve #12
17 GPM's is way more than enough to operate any loader.
GPM's determines speed of operation for the cyls.
More info coming soon (A61569)
More info coming...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A61306)
2016 RAM 5500...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A61573)
2007 Western Star...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
JOHN DEERE 40 BLADE DISC HARROW (A63291)
JOHN DEERE 40...
