Tractor Anti-Lock Brakes
/ Tractor Anti-Lock Brakes #1
SandburRanch
NHtd75
This is the way I see it.
Home owners and tractor operators are going to continue to attempt to mow their too steep hills and rolling their tractors until the government mandates more safety devices. If you think safety interlocks are a pain now wait until this one is implemented. It'll make what we have now only look like a preview. I hate to see it but no doubt it's coming.
http://www.youtube.com/watch?v=4PuN-JZnIZI
/ Tractor Anti-Lock Brakes #2
. . . Home owners and tractor operators are going to continue to attempt to mow their too steep hills and rolling their tractors until the government mandates more safety devices. . .
"You can't fix stupid." - Larry the cable guy
I wish the government would stop trying. ;)
/ Tractor Anti-Lock Brakes #4
I sure wish the guvmint would stop trying to protect me from myself!
/ Tractor Anti-Lock Brakes #5
I wonder if this is NH trying for market share, not abs mandated? I didn't even know tractors had front brakes! Behind, I guess.
Jim
/ Tractor Anti-Lock Brakes #6
Have a look at the tractor/trailer rig in the video. If you go to many countries in Europe that's what you'll find instead of the dump trucks and dump trailers you find here. They run those rigs in traffic at 50mph+ (I'll leave the MPH-KPH conversion as an exercise to the reader) I'm going to bet that that was the main impetus for adding ABS technology to these tractors.
/ Tractor Anti-Lock Brakes #8
Jim
Many large 4wd drive tractors have a mode that when the brakes are used it put the tractor in 4wd to give the effect of 4 wheel braking. This has been an option for at least 4 or 5 years, probably longer.
/ Tractor Anti-Lock Brakes #9
The trailers in Europe are also required to have air brakes. That is coming here soon as well.
/ Tractor Anti-Lock Brakes #10
I don't know about trailers such as fifth wheel or goose-necks but wagons in Europe have air brakes as far as I remember. That is at least 50 years back. It would be difficult to stop a wagon heavier than the tractor. Some usually smaller tractors that are used to pull wagons on the roads have so called highway gear, front suspension and four wheel brakes. In example front brakes are standard on Zetors equipped with high speed transmission imported to USA.
http://www.zetorna.com/html/Specifications/SilverSpec20_40.pdf
/ Tractor Anti-Lock Brakes #11
What is almost a little scary is these large liquid spreaders that hold 9000+ gallons. These monsters are over 100K when loaded being pulled by a tractor that probably weights half as much. Yes they have brakes, but about once a year or so you read about one going out of control either on or off road.
set of 4 tractor trailer tires Roadforce (A63689)
set of 4 tractor...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
CASE TV450B SKID STEER (A65053)
CASE TV450B SKID...
2015 Ram ProMaster 1500 Van (A62613)
2015 Ram ProMaster...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
11" QUICK ATTACH EXCAVATOR BUCKET (A60429)
11" QUICK ATTACH...
