HST vs. Shuttle Shift?
/ HST vs. Shuttle Shift? #41
I don't think that's correct, as I stated in post #31 above. HST's seem to "rob", or utilize, about 1.5 HP more of the engine's HP than non-HST machines.
The exact same tractor as my HST in non-HST format has 1.5 more PTO HP than mine, & I've encountered that same 1.5 HP difference many times.
Yep, if the specs show both engine and PTO HP ratings, and a tractor is available with both gear and HST transmissions, the HST is alway a couple PTO HP lower. I'd estimate around 5-8 percent, n the average.
/ HST vs. Shuttle Shift? #42
I should have said it doesn't degrade pto power greatly. The difference in drawbar power, on the other hand, is very noticeable. My misstatement.
/ HST vs. Shuttle Shift? #44
drawbar HP?
Yep...pretty common measure of pulling power. I've never seen this metric used with CUTs, but larger tractors are rated by drawbar HP.
ack...theres just too much to learn... :confused2::laughing:
/ HST vs. Shuttle Shift? #46
I think the reason the HST tractors always show a bit less HP at the PTO than non-HST tractors is that the HST charge pump always runs if the engine is running. Keeping the charge pump running and the HST pump flowing enough oil to lube and cool the transmission will take a small amount of HP even if the PTO power train goes straight through the HST transmission and the tractor is not moving. Of course the PTO HP numbers are maximum numbers anyhow, with the tractor not moving. When you are driving, the transmission and geartrain supplying power robs engine HP, and the PTO available HP drops. Even without a heavy load, you'll rob power from the PTO.
17in. Tooth Excavator Bucket (A64194)
17in. Tooth...
2021 CATERPILLAR 306 CR EXCAVATOR (A64279)
2021 CATERPILLAR...
2018 FREIGHTLINER M2 FORESTRY UTILITY BUCKET TRUCK (A63276)
2018 FREIGHTLINER...
1259 hrs (A61574)
1259 hrs (A61574)
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
2015 HINO 195 16FT BOX TRUCK (A59905)
2015 HINO 195 16FT...
