18.4-36 vs 18.4-34 on 4230 ??
/ 18.4-36 vs 18.4-34 on 4230 ?? #1
Rmart30
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Ive purchased a 4230 with worn 18.4-36 tires. I have found a company with a set of 18.4-34's on rims. The guy I talked to is not 100% sure that they came off a deere but they look identical to mine from what I can see in the pictures he sent. They are a 5 hour drive from me. Can anyone tell me if the 34 will work on the 4230 or do I need to stick with looking for used 36's ?
New ones are out of my budget.
/ 18.4-36 vs 18.4-34 on 4230 ?? #2
youd have to talk to a dealer to see if the 18.4.34s would work in the place of 18.4.36s.the cheap 18.4.34s are $500 to $600ea depending on what ply tire you buy.
/ 18.4-36 vs 18.4-34 on 4230 ?? #3
The 34s will not work if you do not have the center hubs too. That tractor should have 18.4X38 tires on it.
/ 18.4-36 vs 18.4-34 on 4230 ?? #4
I have never heard of a an 18.4-36. Could they be 18.4-38?
What is posted above is correct. More often than not, the centers would be to big to fit a 34inch wheel on. YOu probably would have to change centers as well as rims.
/ 18.4-36 vs 18.4-34 on 4230 ?? #5
I can't think of a 36" ag tire since the 30's and 40's so it must be a 38".
/ 18.4-36 vs 18.4-34 on 4230 ?? #6
im pretty sure its 18.4.38 as well,because the the next tire up is a 18.4.42.
/ 18.4-36 vs 18.4-34 on 4230 ?? #7
Both of my 4230's have 18.4-34's on them.
/ 18.4-36 vs 18.4-34 on 4230 ?? #8
13.6/36 were very popular on smaller 60/70hp european tractors in the 70's and 80's I have a JD 2130 on them now !
/ 18.4-36 vs 18.4-34 on 4230 ?? #9
I have 13.6R36's on the front of my 6420 :cool:
/ 18.4-36 vs 18.4-34 on 4230 ?? #10
4230 rowcrop's were sold new with either 34" or 38" rear tires depending on which tire size the dealer ordered.
/ 18.4-36 vs 18.4-34 on 4230 ?? #11
Stick with the 38's. You will get much better traction and wear from them in the long run. 34's were real popular in the mid-west where the ground is flatter generally speaking.
Went back and checked again in the daytime and they are 38's ....... I did find quite a few 36's in my search though and as one person said 36's were very popular overseas it seems.
I was hoping the 34's would work ...... I had found 2 of them with 75% tread on rims for $450. Would have been a heck of a deal if they would have fit :)
Thanks for the responses. I will keep on searching for another deal on the right ones to show up
(18) 10'-6" PVC CONDUIT PIPE (A60432)
(18) 10'-6" PVC...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
GREENHECK AIR DUCT FAN (A60432)
GREENHECK AIR DUCT...
UNUSED IRANCH 38" HYD MINI 4IN1 BUCKET (A60432)
UNUSED IRANCH 38"...
2014 Mazda 2 Hatchback (A59231)
2014 Mazda 2...
(2) 300 GALLON POLY TOTES W/CAGES (A60432)
(2) 300 GALLON...
