Extra parts... ??
/ Extra parts... ?? #1
JerryK
Elite Member
Vanderbilt, Michigan, USeh?
Mahindra (2011)5035 HST TLB & (2016)2555 HST Cab & (2017)1526 HST(2018)Cub Cadet Pro Z 154L (1991) Caterpillar E70B
Howdy, anybody with a Mahindra backhoe know what these brackets are for. I figure they have something to do with the 3pt on a backhoe equiped tractor. Maybe extensions for the anti-sway bars for clearance..?? Everything seems to clear the sub-frame fine the way it is now.... Thanks.... Jerry
/ Extra parts... ?? #2
They are sway bar extensions. I haven't seen them used on the 585 backhoe, but have seen them used on the 509/511 on the 20 series tractors. I haven't sold any 585 backhoes as yet, so just because I haven't seen them doesn't mean they shouldn't be there.
/ Extra parts... ??
Thanks... maybe they come with the backhoe kit just in case you need them. My lower 3pt arms and the sway bars clear the 4pt backhoe frame OK now...but maybe I will find I will need them someday....
/ Extra parts... ?? #4
They are sway bar extensions. I haven't seen them used on the 585 backhoe, but have seen them used on the 50 9/511 on the 20 series tractors. I haven't sold any 585 backhoes as yet, so just because I haven't seen them doesn't mean they shouldn't be there.
Jerry,
Galen is so right.:thumbsup: I have to use them so my telescopic sway arms clear the tractor half of my 511 subframe.
Have you had anything hanging off of the 3PH yet?:confused3: I would check it to make sure in a tilted, turn the arms will not contact the subframe when the lift is raised.:mur: Or you can send them to me.:cool:
hugs, Brandi
/ Extra parts... ??
Jerry,
hugs, Brandi
I had my big snow blower [ that thing us up north folks use during the winter half of the year to move frozen percipitation off our drives, painted black, by the way ]. Nothing seems to rub, yet..!!! I am making a one ton ballast for the rear using the same bottom 3pt spacing as the blower, so that should be OK too. If I remember correctly, it was 26 or 26 1/2 inch...which most of my other stuff use, too. But I will keep them handy. Thanks for the offer, though....:)
/ Extra parts... ?? #6
Jerry,
Put them on a shelf in the back of the barn.:thumbsup: In 20 or 30 years, your kids will try to figure out why you kept stuff that was not used.:laughing::laughing::laughing:
hugs, Brandi
Vertical Steel Well Tank (A61570)
Vertical Steel...
2018 Roadtec RP190E Wheel Asphalt Paver (A61567)
2018 Roadtec...
2016 FREIGHTLINER CASCADIA 113 6X4 T/A DAY CAB (A59909)
2016 FREIGHTLINER...
2013 Volkswagen Diesel Passat TDI Sedan (A61569)
2013 Volkswagen...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 NEW HOLLAND WORKMASTER 35 TRACTOR (A62130)
2013 NEW HOLLAND...
