M7030 Blow-by (HELP)
/ M7030 Blow-by (HELP) #1
Sackett876
Kubota M7030
I have an M7030 that has been trouble for a while...It has been used little except in fall of year,,,mainly since I got it because of oil blow-by out of blow-by tube...Year before last when the problem started it would start blowing oil out only after it got hot (not really hot but I mean when used for say 10-15 minutes) anyway when it would start blowing out, I could drop to idle & it would stop leaking,,,run it a while (from 1 minute to maybe 15-20 minutes) start again, drop to idle stop....Have had it to Kubota Dealer 2 times costing me a fortune,,,last year the owner of the shop told me that he thought that the sleeves were rusted (pitted) from sitting, when run it was allowing oil to pass by, thus out blow-by...Now this year it is BAD to the point that I can't run it, it is blowing the oil out faster than I can pour it in!!!! Also, when I take the dip stick out when running it blows oil out the dip stick tube like OLD FAITHFUL!! thus, there must be compression in the oil pan....Which makes sense to me if the pitted sleeves theory is correct.... What do any of you think??? Where can I get a Sleeve/Cylinder kit, other than local Kubota dealer?? Thanks so much!!!!
/ M7030 Blow-by (HELP) #2
I don't think your problem is pitting...
BUT you will not know for sure untill you remove the head and look what you have...
I would try to isolate what cylinder is causing that blow by... you can do it by interfering with the fuel to the injectors, one cylinder at a time... KennyV
/ M7030 Blow-by (HELP) #3
I'd suggest performing a compression check on all cylinders.
Ok how do I do this?? By loosing the injector while it is running,,,one cylinder at a time???
/ M7030 Blow-by (HELP) #5
Don't matter it has to come down, all the way down. You likely have a broken ring or a couple broken rings. It will necessitate new sleeves, pistons and ring sets.
The previous owner abused it. Sleeves don't pit as a rule unless there was water in the cylinders. No cavitation problem, Kubota engines are parent bore.
It's worn out.
It's worn out.
Does anyone know of an aftermarket store to get a Sleeve piston overhaul kit???? Been on internet all day:( no luck yet...Ok just saw the parent bore part,,,so what I am gonna have to do is pull the block to be bored??? or only if scored????
/ M7030 Blow-by (HELP) #7
You're not going to find a sleeve kit for a kubota due to the parent bore design. You're likely looking at having the block bored, sleeved, and new pistons, rings, bearings, and seals IF the block can be sleeved. If not, you're looking at a new engine block on top of all of the other parts.
A parent bore engine has the block cast around the sleeves. They're integrated into the block, per say, and cannot be "swapped out" like a wet sleeved engine like a JD or Perkins in the MF tractors. You're looking at a comprehensive (and expensive) overhaul.
OK so I'm really getting educated here...I'm a fair "shadetree" mech., but the pros here are helping greatly, for example 5030 I read your posts from Feb-2006 in regards to m-series tractors...from what I gathered there the M-series can be re sleeved,,,?? where you wrote & I quote;
"BigCajun:
You can resleeve either type, it's just harder to pull the liners on a parent bore engine....you need either a screw type liner puller and a 3/4" drive impact wrench or a hydraulic liner puller. There is another way though. Run a weld bead vertically from the top of the liner to the bottom. It shrinks the liner away from the block wall and allows easy removal.
There is another type of diesel though not very common and that is a bored block and no liner. That's a throw away engine.
I'm going to do my 1085 this summer. It's a Perkins parent bore.
A wet linered engine has to have seals on the liners or what is called crevice seals to keep the coolant on the wet side of the liner and not on the combustion side. Parent bore/dry linered engines need no seals as the liners are a dry interference fit in the block itself."
Am I reading this correct???
/ M7030 Blow-by (HELP) #9
Depending on what you find it may be cheaper (and easier) to get a new short block and abandon the old block. If it is not too bad you can have it rebored and then move up to the next piston size. Either way you will be looking at a complete engine job.:mad:
/ M7030 Blow-by (HELP) #10
Sackett, do you have any idea how many hours on your tractor?
/ M7030 Blow-by (HELP) #11
This is by far the most affordable option, if it's possible.
/ M7030 Blow-by (HELP) #12
Unfortunately, people tend toward the worst possible situation. There are several things that can cause blow-by that have nothing to do with a damaged block. Do a compression check and find the cylinder with the problem and work from there. When you have identified the problem you can explore your options to repair it. Until then, all the long distance guessing accompanied by the doom and gloom can be counter productive.
/ M7030 Blow-by (HELP) #13
I understand your point, but what do you propose he do after he finds the cylinder causing the blowby? What else could it be other than a worn out or broken ring? If the ring broke, it scored the cylinder requiring a boring or resleeving.
/ M7030 Blow-by (HELP) #14
You are correct, the first thing to do is find out the problem. Unfortunately with a parent bore engine there is never a real happy solution to repairing them. Blow-by is an indication of a fairly serious problem that usually requires expensive/extensive repairs.
I have had to the Kubota Dealer 2 times!! And another mech. 1 time,,,,both say compression is good...tractor smokes 0000, none no smoke,,,,no lose of power!!! One thinks that it is bad o-ring in injector pump, having said that this pump has less than 50 hours, over pass 3 years....Kubota Dealer is who told me that he thought it was rusted/pitted cylinder walls??? Just some more on the tractor...
/ M7030 Blow-by (HELP) #16
Unless you are in a big hurry to get it up and running again I would do a compression check and then pull the head. Once you know more about what's wrong then you can look into all repair options. It's not likely but you could find the head gasket blew and instead of leaking to a cooling water port it's leaking to an oil passage port.
/ M7030 Blow-by (HELP) #17
"BigCajun:
Oddly enough, I had a Massey 1085 with a Perkins naturally aspirated 4 cylinder diesel that had a broken compression ring and it scored the liner. It was shrunk in or parent bore as well.
On wet linered engines, the liner sits on crevice seals and the deck height (top of the block) plus the stickout determines the liner height after the head is torqued down. The head pushes the liner on the crevice seals and excludes coolant from the crankcase. The headgasket seals the top of the liner against coolant and oil leakage into the combustion chamber.
With shrunk in liners, the liner is installed cold (as in dry ice cold) and dropped into the parent bore and set level with the deck before it has a chance to expand. They can be removed with a hydraulic puller (that any competent dealer has) or by running a weld bead (SMAW) vertically inside the liner, top to bottom, 180 degrees opposite. The weld shrinks the liner and it will actually become loose in the bore. That's how you pull 'em on a Perkins or an Oliver.
Never pulled a liner on a Kubota. Never had a problem with a Kubota engine. Mine have all been bulletproof.
Knock on wood.....lol
/ M7030 Blow-by (HELP) #18
.........A wet linered engine has to have seals on the liners or what is called crevice seals to keep the coolant on the wet side of the liner and not on the combustion side. Parent bore/dry linered engines need no seals as the liners are a dry interference fit in the block itself........
Additionally, the oil and coolant passages are in the block casting and have no physical contact with the liner at any time.
You have no need of running anti-cavitation additive (DCA4) and/or extended life antifreeze because there is no direct contact.
The only advantage in extended life in a parent bore engine relates to the radiator itself. The extended life resists solder bloom and Ph degradation.
/ M7030 Blow-by (HELP) #19
I would wonder what the hours are and the type of running and jobs this tractor has done.
I've seen tractors that have glazed the cylinders from running cold. This will give you the trouble that you have.
/ M7030 Blow-by (HELP) #20
Hey Art, could you define 'running cold' for us who are new to diesels? I have yet to start it up when it is very cold out. How long should the engine warm up in various temps. before moving? Is there a chart for this anywhere? Thanks!
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A65054)
2001...
2023 Kubota L3560 Compact Utility Tractor with LA805 Front Loader (A63689)
2023 Kubota L3560...
Livestock Catch Chute (A66408)
Livestock Catch...
2021 CATERPILLAR 289D3 SKID STEER (A65053)
2021 CATERPILLAR...
Striker Slide in Spreader Box (A62679)
Striker Slide in...
2007 Freightliner Columbia 120 Single Axle Day Cab (A62613)
2007 Freightliner...
