Loader New Operators, lets grease our Front End Loaders!
/ New Operators, lets grease our Front End Loaders! #1
k0ua
Epic Contributor
Branson, Mo.
Kioti DK35se Hydrostat
This thread is to assist new operators in the general principals on how to grease their Front End Loaders for the first time.
Let me start by giving you my credentials, this will be the easy part, I have none. I am a Sales Engineer for a Telecom company,
and have spent about 40 years doing technical electronic work. I have owned 4 tractors over 19 years. Now lets move on.
Step 1, read the manual that came with you loader, it should have some good info. Mine say to grease the loader every 10 hours.
This is just an estimate, of course if you mow 10 hours and your loader is off in the shed.. well...you get the idea.
I would suggest you check you loader for proper lubrication when it comes off of the delivery truck. You can assume it will be properly
lubed by you dealer/mechanic. Mine wasn't I did check all the grease zerks, and saw a nice wad of pretty orange grease by each one, and a
assumed it was greased. Went to work with it, "what is that infernal squeaking? and why is it getting louder?" I looked again and found 3 of
the zerks still had pretty orange paint over them and had not taken any grease. Look into the joints and make sure grease has flowed out of
the pins and overflowed the joints. Lets say yours was properly greased and now 10 hours of loader use has passed, (grease on every multiple
of 10 on your hour meter) and you are ready to tackel this job. I am going to assume some of you have never held a grease gun in your hands.
Some of you may say "which grease gun should I get?" It doesnt matter to me, I have 3. A 14 oz manual, a 14 oz. air powered, and a little 3 oz
oz mini piston type handheld. I use the mini pistol handheld more than the others. It mostly depends on how much greasing your are going to do
the mini guns are good for greasing your loader, If you have a lot of greasing to do get something else. A lot of the guys rave about the lincoln
battery powered unit. So lets start greasing. I park my Kubota on a nice Mostly flat shady gravel driveway. and shut off the machine with the
loader raised about shoulder high, and the bucket level. Dont get under the loader, hoses have been know to break suddenly, valves have failed
and the most likely thing to happen is someone will "play or touch" the loader control and mash you. a neighborhood child perhaps, or a thoughtless
adult. I grease the 4 pivot pins first. On my Kubota they are easy to get to as they are facing the sides. I carry a knife and a supply of wipe
rags. to pick out any dirt/old grease and wipe the zerk down good so as to not introduce any dirt into the pin. Now here is the thing about grease
gun tips, here it comes, they are "knurled" for a reason on the tip. They unscrew with your thumb and finger so that the 3 or 4 jaw chuck inside
may slip over the zerk easily and you can tighten them while they are on the zerk if you desire so that they do not pop off from the pressure, and
you may loosen them again to remove them instead of yanking, and shoving them side to side which breaks off the zerks or pulls out the press in kind.
I have never ever broken a zerk, yet they sell grease zerks in bulk. The oldest person that confessed to not knowing that little bit of information
was 72. So after you have greased the 4 pivot pins between the loader frame and the bucket, I move on to the lift cylinders which will be down low
and if the loader is raised will be convenient to get to. The curl/dump cylinders may be too high for you to reach depending on how high your loader
is, we can get them in a moment. If you have Skid Steer Quick Attach, there are two more zerks that will place you in harms way to greas if you
try to do it while it is raised. Best to do them later too when the bucket is on the ground. Now lets lower the lift. You do not need to start
the tractor, just walk over to the control and lower the lift while standing out of the way. Comes down pretty fast doesn't it?. It would come down
even faster if a hose broke. Now the curl/dump cylinder ends joints can be greased, and a new set of zerks are showing the pivot pins on the loader
posts usually gotten fron the top or thru a hole in the loader post will now be available for greasing. Dont forget everything on one side is the
same on the other side. Now is the time to walk into the area behind the bucket and the loader torque tube (round tube between the loader arms) and
bend down and get those SSQA zerks on the barell that the retainer latch pins run up and down in. Some are now asking "how much grease do I pump in"
Well enough to force out the old grease and any dirt that may have crept in, and new grease is showing up around the joint and pins. This may be 2
pumps, this may be 10 pumps. If you keep up with it and grease often, the less it will take each time. Wipe up excess, Escpcially off of the pin
ends where you are liable to come in contact with it as you get on and off the tractor. Oh by the way, I forgot to mention the best thing you can
do is wipe some grease on your hands and maybe just a little on your shirt before you start, because you are going to get greasy anyway. Some will
say to put on lotion on your hands first as that makes the grease easy to get off, or wear rubber gloves, etc.. Do whatver floats your boat in this
department. Some will say to run the loader up and take the weight off of the bucket, and grease again to distribute the grease as it may not move all
the way around the pin. You can if you like. I think it distributes around the pin pretty well in normaluse. If you keep up with greasing and never forget
you will never have any trouble with impacted zerks, or dried up grease channels. If you don't you will more than likely have problems. They are clogged
up with dried out grease and dirt, and of course this lead to accellerated wear. They make tools to clean them out in place, or you can start taking out
pins and clean them up externally. Well I have yapped long enough, I hope this helped a few, of you, because that is my only goal of this post.
James K0UA
/ New Operators, lets grease our Front End Loaders! #2
James K0UA
Thank you for the info. What happen to the formatting? It's very difficult to read.
/ New Operators, lets grease our Front End Loaders! #3
I agree on the 'hard to read' but here on TBN, that's the way it works unless you hit enter twice after a sentence, or paragragh.
I did find a mistake that needs corrected, it's near the beginnig:
"I would suggest you check you loader for proper lubrication when it comes off of the delivery truck. You can assume it will be properly "
Highlighted word should be 'can't'
/ New Operators, lets grease our Front End Loaders! #4
Very informative and worth reading. I appreciated the detailed information. Happy Tractoring.:thumbsup::tractor::tractor:
/ New Operators, lets grease our Front End Loaders! #5
I read on here (can't remember where) that if you wack a pin (with a brass hammer) that doesn't want to take grease, that will cure it.
I can tell you from personal experiance, it works. Before I grease, I tap every pin on both the loader and backhoe with a brass hammer.
Bob
n8zcc
/ New Operators, lets grease our Front End Loaders! #6
It is convenient to grease when the loader is in the air but if you lower the loader and take the pressure off of the pins they will except grease better and more evenly.
MarkV
/ New Operators, lets grease our Front End Loaders! #7
I have those little rubber caps over every one of my grease fittings on my tractor. They are cheap to buy. Ebay and most good parts stores have them.
They keep mud and water out of the grease fitting.
Here is a plus to using them. I remove all of them at one time before greasing my tractor and replace them on each fitting after I grease it then I don't have to remember if I greased the fitting or not.
Thanks for the comments and additions guys, Yeah sorry about the format, I wrote it in a text editor, and made the length of each line too long so it wrapped it to a new (short) line.. I will try to do better next time. I just noticed so many new owners on here lately, and some asking about greasing, I am thinking some have never done it, and the purpose of this post was to just make a start and bring some more posts to maybe help these new guys a bit.
James K0UA
/ New Operators, lets grease our Front End Loaders! #10
k0ua - Really a timely thread for me! I was worrying about grease just the other day.
Some are now asking "how much grease do I pump in" Well enough to force out the old grease and any dirt that may have crept in, and new grease is showing up around the joint and pins.
My question is: For a simple pin joint such as on a FEL or MMM wheel axle, should I pump until new grease comes out of ONE (either) end of the joint, or out of BOTH ends? I don't believe any of the pin joints on my FEL readily give up grease at both ends. Consequently, I worry that my greasing effort may be in vain. Is there a trick to get grease out of both ends of the joint?
Some say to have the loader on the ground to relax any tension in the pins, you might try that, but usually I just pump until I see clean grease and assume it will spread as I use the loader. Most people say it is better to overgrease than undergrease, You might use the loader a bit and do it again to make sure it is spreading. Wont hurt.
There are actual mechanics and heavy machine operators on this forum whose credentials are much better than mine, my purpose was to get a discussion started to help new folks a bit.:thumbsup:
James K0UA
/ New Operators, lets grease our Front End Loaders! #12
:thumbsup: Good post. It's a shame to say, but it's not only noobs that fail to grease equipment.
I do want to add my :2cents: worth to some of your thoughts.
. . .Let me start by giving you my credentials, this will be the easy part, I have none. I am a Sales Engineer for a Telecom company, and have spent about 40 years doing technical electronic work. . .
. . . and a little 3 oz mini piston type handheld. I use the mini pistol handheld more than the others.
. . . I have never ever broken a zerk, yet they sell grease zerks in bulk. . .
That would absolutely qualify you as an expert on tractors, probaly politics too. :D :laughing:
Manual, what manual? Real men don't need no stinkin' instructions! :rolleyes:
You just don't use as much grease as I do. I buy the big tubes by the case. :D
Here's the grease gun that I use, the pistol grip at the top of the page: JohnDeere Grease Guns and Accessories JohnDeere.com
And, yes, you can use a JD grease gun on other brands of equipment. ;) Actually, I bought my first JD pistol grip grease gun before I owned a JD tractor. It was probably 25 years ago. I'm not sure who makes these for JD, but it's the best gun I've ever used.
Again, you don't use as much grease as I do. It will happen. Also, if you operate dirt equipment, run a plow with coulters, or even use your FEL a bunch in the dirt, you will have to change a zerk every now and then. Also, you can just break them off while you're using them. (back into a tree, scrape against a fence post, etc) They're cheap and I buy them in the assortment pack, both SAE and Metric.
I used to use 10 times or more grease than I do now, When I used to mow at least every 2 weeks, I bought the 14 oz tubes by the case. Greased every time I went out. But I dont have that kind of property now, I kinda miss it.
It was pretty while I had it. I have driven by there again, it doesn't look like when I left it.
James K0UA
/ New Operators, lets grease our Front End Loaders! #14
I grease mine every 8 hours of operation per Brush Hog recomendations. I keep a log book in the garage and watch the hour meter.
/ New Operators, lets grease our Front End Loaders! #15
Thanks for the reminder, I noticed my new (a year now) loader squeeking the other day, guess I better check the grease.
/ New Operators, lets grease our Front End Loaders! #16
Regarding taking load of the loader pins and accessing the bucket & QA pins; I dump the bucket over so cutting edge is vertical then lower it to ground and put lift arm in float position. That way all my zerks are easily reached without moving the loader.
I also grease the tie rods, front axle pivot and hydrostatic pedal linkages at the same time. 1 or 2 pumps for those with boots on them, so to put some grease in without blowing out the boot.
/ New Operators, lets grease our Front End Loaders! #17
I also appreciate the reminder. I was working with the loader Saturday and was noticing some squeaks. My tractor has 27 hours on it. After seeing this thread, I checked the loader manual and then picked up a tube of grease on the way home from work today. Just finished. Hopefully the squeaks will be gone now.
Just think of all the happy loaders now that will finally get some grease:D
hey ssdoxi thanks for the tip:thumbsup:
James K0UA
/ New Operators, lets grease our Front End Loaders! #19
While greasing your front end loaders check the shoulder bolts that are used on the QA mechanism. One wiggled out and is lost somewhere on the 80 acres. Replacement is now secured with blue Loctite per KMW factory. Just another item to look at while greasing the FEL.
idaho2
/ New Operators, lets grease our Front End Loaders! #20
After about 4300hrs I've figured out that some of my pins need more grease than others. Normally the pins closest to thge bucket move thru a greater arc so need more than the pins on the mounting posts.
I also find that if I study just where the zerk is located, I can tell if the weight of the bucket/arms is putting pressure on the spot that I am trying to inject grease, in which case I rotate the bucket/raise lower the arms/ or just lower everything to the ground and push down. This will give a bit more space for the grease to flow.
I have also removed many of my pins over the years and us4ed a small grinder to create grease grouves in them. (especially on my hoe)
2022 EZ-GO ELITE...
2006 Volvo VNM S/A Day Cab Truck Tractor (A64556)
2006 Volvo VNM S/A...
2020 KENWORTH T880 DUMP TRUCK (A65054)
2020 KENWORTH T880...
2008 Freightliner Allegro Bay Class A Motorhome (A61574)
2008 Freightliner...
Landhonor 3-Ton 3-Bag Air Jack (A66408)
Landhonor 3-Ton...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
