bindian
Super Member
I got them framed out, but when I started the tractor to go fetch more logs I had either a water pump or thermostat failure...it was blowing coolant out of the overflow, white smoke, then after shut down I could hear coolant draining back into the block for abour 30 seconds. I loaded it onto the trailer and will have to run it to the dealer tomorrow. This is not good as I use my tractor almost daily on the house build not to mention we have hay on the ground again that I was supposed to bale tomorrow afternoon.
It's always something, eh?......{sigh}
Rick,
Whoa here now.:smiley_aafz: You meant to tell us you can build your own log house, yet can not troubleshoot and replace a water pump or thermostat on you near and dear tractor?:mur::mur::mur:
Houston.......................we have a problem!
I wish I was closer to Y'all. I would come over and fix Bessy so she can haul logs for you.....................just to see you continue your log house work.
hugs, Brandi
