Tractor in the mountains
/ Tractor in the mountains #1
CLkid
2010 Kubota L3400
We have a L 3400 Kubota that has exceeded our expectations. However, since we are in mountains of Northern Colorado the land is NOT level. Any one have any idea how much slope it takes to put this tractor on its side, something I do not want to do. I know it will make a difference if there is a load in the bucket and the amount of weight I have on the back end, but there must be some number that indicates the degrees of slope to stay away from. I'm bascially a chicken when it comes to slope with this tractor. Along anther line of thought, I have read many things about attaching a backhoe to tractors of this size. Any one have any experience with a backhoe on an L 3400. Has anyone come up with an economical solution to additon of weight on the backend. I have a blade on the 3 point and have attached bar bell weights onto the blade. Seems to work, but I would like more weight than the estimated 300 pounds I currently have. Thanks and have a good day.
/ Tractor in the mountains #4
That number is commonly called "the pucker factor" you will undoubtedly experience it , just don't or try not to over exceed it.
/ Tractor in the mountains #5
Welcome to TBN, I have a L2800 which is the exact same as your but just a few less horses. I have a backhoe on mine and leave it on most of the time. It is a great counterweight, get a thumb for it too, as well as handy as a mini crane and oh yea it digs pretty well too! I also put duals on it front and rear, I did it for floatation on the beach but it gives me incredible stability on the side hills too. Unverferth.com makes duals for the rear for your tractor.
Rick
/ Tractor in the mountains #6
"Pucker Factor" = If it scares you, don't go there.
10, 20, 30, Degrees really has not meaning in many cases. What was safe yesterday, may not be safe today. Damp ground, low wheel hits a low spot, high wheel goes over a rock or bump.
Keep your FEL bucket very close to the ground. Real important if loaded. If you have a back hoe swing it to the up hill side.
Class Dismissed - Time for a cold one. :laughing::thumbsup:
/ Tractor in the mountains #7
The operator's manual for the L 3400 Kubota just might have that information. Read the book and don't go by what someone that says that they have worked tractors on 45 degree angles all their life.
If you are working on inclines where having to depend on the position of the bucket, back hoe counter weight and ballast you are at risk.
And degrees of slope / angles aren't all that difficult to measure. Get some numbers to go by.
/ Tractor in the mountains #8
Welcome to the forum. Do you have your rear tires filled with liquid ballast? Often referred to as "loading" the rear tires. It makes a huge difference in stability and traction by adding weight below the center of gravity. A search on the forum will give you days of reading.
While searching look for "ballast box". As the name implies it is a box or container of weight that hangs off the 3pt hitch. Home made versions would include a garbage can or drum filled with concrete.
I don't know if the L3400 has the capability to set the rear tires to different widths. If so you want the widest setting. On some tractors the axles are adjustable or the wheels are reversible to achieve a wider stance for stability.
MarkV
/ Tractor in the mountains #10
I've looked for this info in my manual and couldn't find anything. Also looked in service manual and online. All I can find is the highly descriptive but imprecise "pucker factor".
One of the things on my todo list is to simulate a rollover by putting a floor jack under one side of my tractor and start lifting. I'll keep the ROPs and FEL frame strapped to a big tree with a ratchet strap and keep lifting and loosening the strap until it starts to tip and just puts tension on the strap. That's the point where it would roll over. That at least gives me some idea whether it's 15 degrees or 75 degrees. I've watched the road crews go by and mow the sloped ditch in front of our house, they have a beer in one hand, a magazine in the other and don't even slow down. I'm out there like Barney Fife worried my tractor is going to roll over. I'm with you, I'd like to get some idea where the danger point is.
/ Tractor in the mountains #11
If it FEELS like too much slope, it probably is..
Take your time, and what feels like too much slope today, may not feel like too much tomorrow. Just let good judgement be your guide ..
/ Tractor in the mountains #12
I try to inspect the area for holes, stumps or other obstructions in steep areas, go slow, keep bucket low (but not too low in case you hit something...even a low spot), engage 4WD, go straight up and down, and make sure the ground is dry. I use the pucker rule as well....
/ Tractor in the mountains #14
I have a L3400 with loaded tires and a Woods back hoe. I usually have either my back hoe or bush hog on the back of my tractor for counterweight when using the FEL. I have some ravines on my property that I work in occasionally. I use my seat to feel what the tractor is doing, you will know when it is time to stop.
Just listen to yourself, don't turn sharply, I have had a tire roll off the rim with a load of dirt on the FEL bout 5 ft. in the air going down hill. That was right after I got my first tractor and it was not a fun situation. I didn't have anything hanging on the back of the tractor as a counter weight. I stopped and asked my wife to take some dirt off the loader while I counter balanced the tractor by standing up and back. Unfortunately, she started taking dirt from the wrong side, I stopped her in a hurry. I eventually lowered the FEL and was able to maneuver the tractor safely out of that situation. Common sense and feel are your friends.
You are getting good advise from everyone. Good luck.
/ Tractor in the mountains #15
I find my L3400 to be very tippy. I had a Massey Ferguson 35 for 20 years before the Kubota, and I never even thought about it rolling over, but with this one, I've had a wheel off the ground a couple of times and it would't have taken much more before it tips. I bought a tilt angle gauge for mine that I saw advertised on Tractor By Net, and I can say that about 15 degrees would be getting pretty uncomfortable.
/ Tractor in the mountains #16
Just for fun when my new L3400HST arrived off the truck the first thing I did was run over to the gravel pile and see what it was like to lift a load of crusher run gravel with a "bare" tractor. No loaded tires and no 3pt weight. Let me tell you friend it was scary. any slope at all and it wanted to lift and tip. This is with the wider R4 tires. No they are not adjustable in any way, but they do sit a little wider than R1 would be. So I started to "fix" the stability problem. The first thing was to build a ballast barrel that weighs about 750 lbs. Then loaded the tires myself for additional weight down lower when the mower is on and it also helps with the loader work. Now I can tie into a full load of gravel even on a slope and don't have that "tippy felling" all the time. Oh don't get me wrong, it is still possible to tip over, but a lot less likely now. Of course common sense when mowing on slopes like the others have said about looking for rocks on the high side and holes on the low side are always neccessary. Here is link to some photo's of my ballast barrel. Post 26 has some pics of mine, but there are several ideas in this thread. Good luck in your search for more stability.
http://www.tractorbynet.com/forums/...94-rear-ballast-gentlemen-rear-ballast-3.html
James K0UA
/ Tractor in the mountains #17
I don't know if your model has a seat belt and ROPS but if it does have a seat belt, wear it anytime you're on a slope. It won't prevent a tip over but it will keep you in your seat.
I'm also on hilly ground. I have a ROPS on my B26 and use my seat belt anytime I have to go sideways. I'm still learning how to use my tractor and I really believe in the pucker factor. I have a low threshhold for being crushed and mangled so I always err on the side of caution.
/ Tractor in the mountains #18
There is no magic number regarding safe slopes.
There have been times when I've run my machine on a slope I thought would pick up a tire, and it didn't, yet other times when I was on a much shallower slope and one tire running into a small dip gave me the feeling that a tip was beginning.
You have to use your butt-meter, internal-pucker-meter, whatever. YOU are the one that has to determine what it safe based on knowing the machine, experience on the machine, using your senses, etc. If you don't trust your senses and your ability to determine what is safe or not, then you probably have no business operating a machine in those conditions. Trust your instincts. Start slowly, and let experience tell you what you can and can't do on the slopes.
I've used my backhoe as a counterweight in situations that I wanted/needed to get the tractor into, but was concerned with tipping. I've extended the hoe out on the uphill side and lowered the outrigger to just above ground level in a few instances, so that if I did initiate a tip, there was something to stop the process. And VERY slow machine movement - the faster you're running the machine, the faster a tip happens and the less time you have to counteract it.
My feeling is that if you try to rely on a gauge, you have a better chance of getting into trouble than if you rely on your own senses and experience.
3.5 years on my mountain property at 8500' with very little flat area, a ton of earth moving, and no major incidents. Why? because I am always aware, and when I am pushing what my senses tell me are the limits, I do everything possible to counteract a possible tipover, including the backhoe tricks I mentioned, using loaded tires, keeping the bucket as low as possible, with hand on the joystick ready to drop it to the ground if things get tippy, and taking my time.
/ Tractor in the mountains #19
What type of tires?
Many circumstances..damp ground from rain/dew..roots etc..etc..couple good bounces and OMG,..good set of tire chains can make difference...yep go w/your gut feeling.
/ Tractor in the mountains #20
Good advice here. Hard to give a single number answer to CLkid, but as others have noted, the pucker meter should be pegged when you're getting above maybe 10 degrees = 20% side slope. Since you're in the mountains, it's obviously easy to find much steeper terrain than that, and your caution is well justified.
213141 (A64276)
213141 (A64276)
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A65054)
1994 CHEVROLET...
2018 CATERPILLAR 573D FELLER BUNCHER (A65053)
2018 CATERPILLAR...
1979 Ford 5000 (A64126)
1979 Ford 5000...
Ford Tractor (A62613)
2018 F-150 4WD (A63688)
2018 F-150 4WD...
