Quick Hitches Problems with Quick hitch on B7800
/ Problems with Quick hitch on B7800 #1
b7800man
kubota b7800
i was wondering if anyone has had problems who has switched there b7800 to a quick attach front? anything like less lift cap, or more trouble then it is worth. i want to do it to mine, but for the money i want to make sure it wont be more of a pain then it is worth. thanks all
/ Problems with Quick hitch on B7800 #2
Are you referring to the Kubota Quick attach (not skid steer type)? If that's what you are referring to then yes, I just converted mine to that setup a couple months ago. I too was worried about reduced lift capacity, less roll-back force, etc but found it to be a non-issue. One added benefit is that it put the bucket a little further away from the tractor which actually makes is easier to see and seems like it's easier to make a level cut with it also.
/ Problems with Quick hitch on B7800 #3
What QA are you looking at using? I've just been looking into this myself, and wondering if the brackets from the B-3200 will fit the LA-402 ..
i was looking to put on a skid steer attachment, seems like it had more options then the kubota one. i believe ATI makes one, but i really hadnt thought about brand yet. so please keep posting, i want all the pros and cons before i drop a grand or two
/ Problems with Quick hitch on B7800 #5
I know some guys here have done the skid steer conversion. Quite a bit of cutting and welding.
Looks to be a fair amount of steel, and consequently a fair amount of weight, and it out far.
Whatever weight is added is subtracted from the lift capacity.
/ Problems with Quick hitch on B7800 #6
I made my own and couldn't be happier.
i know there is a lot of welding if you keep you bucket, my intent was to trade in my bucket for a bobcat made one, it was only $100 more then welding plate and labor, this way i don't loose the structural strength of the bucket. so the added weight wasn't as much of a concern as the move out, and any other unforeseen problems.
so the man with the big rock, is your a Q/A? i couldn't tell from the pic, it it is do you have any more pics?
/ Problems with Quick hitch on B7800 #8
I have the ATI SSQA and love it. I worked it into the deal when I bought the tractor last yr. As for the bucket the dealer kept my original bucket and put on a Woods 60" bucket that comes predrilled for a reversable cutting edge. All in all I think the setup is great, i use my forks as much as I use the bucket.
/ Problems with Quick hitch on B7800 #9
Yes it is. I took the BX Tach-n-Go and adapted it to my B7800. The grapple is a Q/A as well, #100 including the cylinder. So basically all the stuff made for a BX you can use on your B7800. If you want more pics just ask.
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
2004 CATERPILLAR D5N XL HIGH TRACK CRAWLER DOZER (A62129)
2004 CATERPILLAR...
Electronic Towable Sign Board (A61166)
Electronic Towable...
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
