Kioti LK3054 Clutch Problems
/ Kioti LK3054 Clutch Problems #1
MT Kioti
Member
High Elevation in Western Montana
Kioti LK 3054
I have a LK3054 with about 700 hours. The other day I put my foot on the clutch and I kept moving. Doesn't seem to engage the motion or the PTO. I checked the free play in the pedal and it seemed OK, but gave it a few more turns anyway but no difference.
Is there anything I can check or do without taking the whole thing apart? Seems like an week-long project that I don't have time for.
Even bought the Workshop Manual, but didn't see anything very helpful (sure a lot of typo's for $80, pretty drawings though:laughing:)
Any Info would be helpful.
Thanks
/ Kioti LK3054 Clutch Problems #2
How long since you last used the tractor? If it's been a while, the clutch plate may have stuck to the flywheel and your pedal movement will not dis-engage the clutch plate. Sidle up to an imoveable object and see if you can break the clutch plate free.
Thanks Patches,
You're right, it has been over a month since I last used the tractor.
I'll give that a try and let you know what happened.
Well, I seemed to have fixed the problem, at least for now. I tried Patches' suggestion and drove up against to a stump (I knew I left them in for a reason :laughing: ) and throttled up. Something seems to have loosened up a little, but the clutch still didn't FULLY engage even all t he way down on the pedal.
So, I decided to tighten the linkage up a couple more turns to see what would happen. Well, it did make a difference, but still barely a fraction up on the clutch pedal and I started to move, so a few more turns on the linkage.
I finally got it adjusted to what seems right, and I probably put more than ten full turns tightening up the linkage. I'm not sure how it could have been so far out of adjustment and still worked up until a few days ago, unless I bent something under there, but I sure can't see anything out of alignment:confused3:.
Thanks for the info, hope it works well for a while longer.
PS: If anybody needs a page from the service manual (workshop manual) send me a private message and I'll try to help you out.
2018 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 BMW 750i Sedan (A61569)
2013 BMW 750i...
2006 Hummer H3 4WD SUV (A61569)
2006 Hummer H3 4WD...
2016 PETERBILT 365 (A58214)
2016 PETERBILT 365...
TANK MANIFOLD (A58214)
