Fluid Leak from Relief Valve
/ Fluid Leak from Relief Valve #1
Rockin' G Ranch
Point Blank, TX
Kubota L4740 HST with FEL
Fluid Leak from Vent Plug
I finished bush hogging a 3 acre field and loaded my L4740 HST on the trailer when I noticed fluid dripping from under the tractor directly under the dash board. I looked under the tractor and noticed the dripping was from a vent fitting pointing straight down. It was a VERY hot day so I'm sure the tractor was hot but not overheating. Is this normal? What fluid was leaking from this vent fitting? Thanks for the help.
/ Fluid Leak from Relief Valve #2
Does the vent fitting look like the one in the picture?
I wasn't in water. Field was bone dry. Where could this fluid possibly have come from? Unless it had been in there for when I washed it last. The fluid was clear but I didn't check to see if it was water or oil. I will pull the plug and see what comes out.
Pulled the plug and no more fluid drained out. Also, the fluid on the trailer was gone this morning so it must have been water that evaporated. Thanks for the help.
/ Fluid Leak from Relief Valve #7
Good to hear, I never replaced mine as it will only get bent again, so I just remove the plug at 100 hour service time and have yet to have anything come out.
/ Fluid Leak from Relief Valve #8
I would recommend keeping an eye on that. Kubota has had a bit of a problem with the 40 series tractors leaking oil from the trans into the clutch housing via the 4WD shaft.
2004 INTERNATIONAL 7400 20FT T/A FLAT BED (A59914)
2004 INTERNATIONAL...
4022CFL (A59228)
4022CFL (A59228)
New/Unused AGT Industrial SDA-140T Track Loader (A65579)
New/Unused AGT...
NEW IDEA 323 - 1R CORN PICKER (A64277)
NEW IDEA 323 - 1R...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
2013 Ford Taurus Sedan (A64557)
2013 Ford Taurus...
