Troy-Bilt horse
/ Troy-Bilt horse #1
wild bill 63
John Deere 214
I have a troy-bilt horse tiller would it be feasible to put a 13hp Honda Motor Honda Uses 1inch shaft can I buy conversion kit and Honda has Low oil shut I would appreciate your help it has a 8hp Briggs-Stratton on it right now I would like to use the Honda if all possible
/ Troy-Bilt horse #3
The key is the shaft dia.and length. the next would be were/how it sits in relation to the belt speed pulley so that they line up. what about the battery tray ?how much larger is the Honda body?are you replacing the B/S 8hp Eng?. Am asking these questions as am getting ready to replace our eng. as well. Paul
/ Troy-Bilt horse
maybe I go with something like a 10 Tecumseh with a 3/4 shaft or a Briggs with a 3/4 shaft I have done some research the 13 Honda is out of the question my Briggs has a valve rattling problem it has rattled for the last two years maybe it is my old Ford truck maybe rattling what keeps it a going my Brigg is a ohv 8hp I can't seem to get valve clearance right my dealer where I live sucks:laughing:
/ Troy-Bilt horse #5
I have no idea as what size eng. or make to use to replace my b/s eng it still works but is uses as much oil as gas and is getting hard to start that said am in the dark at this time and was hoping I could learn from you. Where are you located?.
/ Troy-Bilt horse #7
I would try to use an engine of around the same size, not much bigger, and no smaller. If you use an engine that is alot bigger, like that honda, you might break something. Also, the engine needs to have the the same size shaft, or it will be a huge pain (and alot of machining) to make it work. If I was doing it, I would put in another 8 hp engine.
/ Troy-Bilt horse #8
Hi"
I consided that staying with the 8hp but I really like Honda products my self although i do have some equipment with B/S newer eng's as well and they run quite well so I was thinking if am going to replace it maybe I should make a change and I got my self confused But I believe your right and I will stick with B/S that will take the pain out of the swap as well I wa just open to any suggestions. Paul
/ Troy-Bilt horse #9
Hi"
you can stll use a honda engine, just use an 8 hp insted of a 13 hp, and make sure it has the same shaft.
/ Troy-Bilt horse
I found a 11 hp Briggs-Stratton commercial engine it has a 3/4 shaft and is designed for the horse tiller I have a lot of clay where I live and it gets hard the motor I found is of the old style Briggs not a OHV model I think it will do the job for me troy uses this motor on the Big Red and think it will do the job for me
/ Troy-Bilt horse #11
Be aware that engines with an oil switch may not work well on a tiller. When tilling the engine leans back as the tines go deep into the soil and depending on where the switch is, it may cut off the engine. You may have to overfill the engine to compensate.
Russell
/ Troy-Bilt horse
The 11 hp Briggs I plan on buying doesn't have a low oil switch it is designed for the Troy-Bilt horse and they use on the Big Red horse I have a lot of clay where I live and it hard to plow with a small motor I rather have a motor too big than one not big enough My tiller is a pto version 3rd generation Troy-Bilt horse tines wear out fast in clay I would like to have some Pick tines Pick tines have been discontinued and hard to find:confused2:
/ Troy-Bilt horse #13
Hi" Wild bill have a coupe of questions since you seem to to be way ahead of me on this project. How do I find out what generation my tiller is? where did you get the information on the 11 hp b/s eng. that your planning on using and what about the elect start set up is it interchangeable or are you planning on a pull start setup?you said that it is designed for the horse but am wondering as to the height of the shaft in relationship to my speed belt pulley . Have you overcome these problems as well? Tk's Paul
/ Troy-Bilt horse
Small Engine Warehouse has the 11hp Briggs already setup for the horse tiller the 4 speed model not the older two speed model they have several engines any brand you want and have kits to go along with them troy used the motor on older models when it was garden way before mtd bought them out to find out what generation tiller you have does it have one belt or two the first generation had two belts the second had one the third was a pto version it has a lever to engage the tines on the back of the tiller all are good equipment can last a long time with right care
/ Troy-Bilt horse #15
Thank you for the info. i will check them out and due a follow up. I think my horse is before mtd it has one belt must be second generation. I bought it second hand back in 91 and it had a mile or two on it then.but not bad enough that a good going over did not cure we use it at least 2 to 3 times a year. Paul
/ Troy-Bilt horse
I recommend you don't buy a motor with a plastic pulley it may save you some trouble stay with the 3/4 shaft one of the reps from small engine warehouse told me they are having a lot of trouble with plastic pulleys I would recommend using a Briggs or a Kohl er Motor Both are durable engines please contact me if you have any problems :thumbsup:
/ Troy-Bilt horse #17
Again thanks for your help and advice Ours has the double pulley and I agree I hate the word plastic would do anything before being forced to use it. yep i will use either one of those engs. But I know the krohler is good a good one we have one in our old yard tractor and it runs like a clock now for the past 16 years with just regular oil changes. We have some new equipment that has the new b/s engs they are new no time test they seem ok but they have not proved them selfs to me as yet was not to overly impressed with them before. I have a few more projects in-front of me now and was saving this one for winter as it can be done inside the shop but I when saw you question it was the same as was my thoughts and I need to talk with some one about this project thanks for the offer to contact you in the future PLEASE keep in touch and let me know how yours is coming along. Paul
/ Troy-Bilt horse #19
Thank.s Reply send via e-mail.now you have my'en.
Paul:thumbsup:
2000 Sakai SV505 (A64119)
2000 Sakai SV505...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
Transfer tank (A61567)
2022 EZ-GO ELITE...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A DAY CAB TRUCK TRACTOR (A59908)
2017 FREIGHTLINER...
2025 GIYI GY-P45 Hydraulic Breaker Mini Skid Steer Attachment (A61572)
2025 GIYI GY-P45...
