Ford 2000 Question
   / Ford 2000 Question #1
Emoryboyd
I've noticed many Ford's have a round vent on the left side of the hood. Our 1969 2000 Diesel does not; just curious about the purpose. Thanks.
   / Ford 2000 Question #2
I believe what you're referring to would be the air filter on some models.
   / Ford 2000 Question #3
My 1971 Ford 2000 has this type of air filter system, except it's all missing. I'm trying to find a used or after market system to put back on it.
   / Ford 2000 Question #4
gassers and disesels had different breathers.. some had wet some dry.. dry ones had an access door... wet models a vent...add to that the tin differences from the 64 and prior models to the 65 and later models... etc.
soundguy
   / Ford 2000 Question #5
My Ford 2000 ('74) had a wet filter (oil bath) behind the removeable plastic grill.
   / Ford 2000 Question #6
I always wanted to know this as well.
Here is my uncles '68 4000. Originally it was a gas tractor but the owner converted it to diesel some years back.
Has the air cleaner sticking up out of the hood in front and also on the side of the hood drivers side-I'm confused??? Was there 2 air cleaners??
The two air cleaners?? is how this tractor came with the gas engine
   / Ford 2000 Question #7
1 air cleaner per tractor.. style depended on model, fuel type, and year.
soundguy
   / Ford 2000 Question #8
the prior models had the oil bath back by the driver, thus the lil rectangular vent on them back there.. etc.
soundguy
   / Ford 2000 Question #9
soundguy
Soundguy I'm still confused. My uncles tractor has the filter sticking out of the front of the hood and also the round filter thing on the drivers side. Is one not a air filter? See the pic I posted. That is how it came new.
   / Ford 2000 Question #10
I see a mushroom style inlet breather cap up front, and a cover for a dry air cleaner filter access back of the hood.
are you saying it also has a dry air filter canister or oil bath air filter sump under the nose too? or is the dry air filter back of the hood it's only filter canister.
the mushroom cap is an inlet... not a filter per se...
soundguy
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2025 Kivel 48in...
2006 Chevy Trailblazer (A47384)
2006 Chevy...
