Power update.
/ Power update. #1
ToadHill
Elite Member
Catt county New York
Kioti DK35, Ford 8N, Oliver Cletrac
Just an update on the post of a week ago regarding a lack of power in my DK35.
I looked at what was necessary to take off the fuel tank and it was a daunting challenge, so I decided I needed to find a better way. I drained the tank and took the fuel gage out of the tank and with a very small flashlight I could see to the bottom of the tank.
I saw some brown globs that was a alge of some kind so I got a 18" long grabber ) that tool you push down on one button and 4 little fingers come out the other end) and mopped up all the alge. I then looked down the tank again and still saw something like a small lump in the bottom of the tank.
After several tried I got it with the grabber and pulled it out, there was a full sized hornet. Just the right size to plug up the fuel outlet when it floated into it's path.
Put it back together and ran it for about an hour and at least for a while all seems well.
How in the ---- did a hornet get into the fuel tank????
/ Power update. #3
Fastening a small hose and steel line to a shop vac will sometimes do a good job of cleaning up the bottom of a fuel tank. I have done that several times on some of my older tractors.
/ Power update. #4
It was a secret drone hornet from area 51!:laughing::thumbsup:
/ Power update. #5
this is funny, My grandfather used to tell almost the same story about his model T It would stop like out of gas then would start up again. In his case it was a spider in the gas tank that would be pulled into the fuel line. Now you can have a story to tell about the "old days" in years to come.
/ Power update. #6
Algae in diesel? Not possible.
/ Power update. #9
Does this mean that over time water, and perhaps the other nasties, are likely to be accumulating at the bottom of my diesel tractor's fuel tank.
Maintenance schedules don't comment on periodic cleaning of fuel tanks.
Doesn't emptying the fuel filter bowl when changing the filter get rid of accumulated water trapped by the filter ?
/ Power update. #10
Well actually the algae grows in the water that is present in the diesel. Problem is that all diesel has water present..some a lot more than others. I have a 300 gal tank. every time it gets filled I add a biocide:
Biocide Racor Fuel Distillate Additive
and a gallon of Power Service:
Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economyPower Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boos
So far I have not had any fuel related problems.
/ Power update. #11
Yes, but we are talking about bacteria and algae that form colonies in the tank big enough to gag the fuel pickup inside the tank. This is was before it gets to a filter. Also, I have read that if you have a real bad infestation, once a biocide is applied and the stuff is killed their little sea monkey bodies can get sucked into the filter clogging it up tight.
/ Power update. #12
Does this mean that over time water, and perhaps the other nasties, are likely to be accumulating at the bottom of my diesel tractor's fuel tank?
Yes, indeed! Every one of my project tractors, which were all
less than 10y old had sludge in the bottom of their fuel tanks. It was
an accumulation of water, bacteria, and probably algae. Only my later
Deeres had a fuel drain in the bottom of the tank, just below the fuel
inlet. Why hasn't Kubota, Kioti, and others done this?
/ Power update. #13
Seems to be a good reason not to let the fuel level get too low.
After 5000 hours I better have a closer look inside my old Kubota's tank.
/ Power update. #14
Since probably all the fuel inlets from the tank to the filter bowl are
above the bottom of the tank, it is more a question of how deep is the
sediment? Eventually, it will rise to the level of the inlet.
Try taking some 1/4" diameter clear vinyl hose and threading it to the bottom
of your tank from the filler hole. Suck on it just a bit, pinch it off, and see
what enters the tip of the hose. If you can get the sludge to enter the
hose, then you can remove some of it that way. In my Deere 4300, the
sediment had become semi-solid, and would not come out of the drain
without encouragement.
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
Cummins 6-Cylinder Diesel Engine with Transmission (A59230)
Cummins 6-Cylinder...
2019 Mercedes Sprinter 2500 Cargo Van (A61573)
2019 Mercedes...
POULAN 44" VINTAGE 2 MAN CHAINSAW (A64276)
POULAN 44" VINTAGE...
2017 Ford F-550 4x4 Venturo ET25KX 2 Ton Crane Service Truck (A61573)
2017 Ford F-550...
3pt 2 Row Bedder (A64119)
3pt 2 Row Bedder...
