Buying Advice Best lawnmower
/ Best lawnmower #1
Nfaile
Member
Cud cadet ltx1040
What would be the best riding mower for a small lawncare buisness?
/ Best lawnmower #2
You need to fill in some details. Like, what size properties do you plan to mow? Small, tight, heavily treed lots will demand a very different unit than large, wide open tracts of grass.
/ Best lawnmower #3
Depends on terrain, space and $$$.
I have a Scag 48" 19hp that I use to mow 3 yards in town and my 3 acres. I paid $6800 4 years ago. I don't know how many hours because the digital hour meter went all goofy. But it has to be in the 7-800 hour range, which not that much for a commercial mower. But I haven't had any trouble at all just belts and fluids.
Take your time. Do your research. You will find the right one. (Just as a side note; go to a dealer, not some box store.)
/ Best lawnmower #4
+1
Lots of good mowers, but Scag is #1 or was the last time I checked.
/ Best lawnmower #5
What size (cutting width)? Do have have any narrow gates to get through? What's your budget? Are you going to use it for anything besides mowing? What brands have dealers in your area?
/ Best lawnmower
I want a cub cadet
/ Best lawnmower #7
and,
"I want a cub cadet"
This seems to start out asking a reasonable question about mower choices and you were asked for a few more details. Without more input from you why should we waste out time.
Go buy the Cub Cadet.
/ Best lawnmower
jenkinsph said:
and,
I ment what would be a good cub cadet for a lawn with a gate the is 42in wide?
/ Best lawnmower #9
Not super familiar with Cub Cadet but the current 1040 series has a 42" deck offering and I would expect it to need about a 45" opening to drive thru.
If you are starting up a lawn care business you need to consider lots of things before choosing your new mower. I wouldn't let a small gate hinder your choices of equipment, you might be better off shopping for a new wider gate first. I would do some research as to what customers needs are and are willing to pay you for. Spend some time to figure out what you need the most and then consider everything including a trailer to work with.
I do alot of landscape work and consequently need to get in some tight spaces from time to time. I find I need about five feet of space to use the mower as a minimum. In your case with a mowing business you will need a pushmower for tight spots.
You might find that a lawn tractor with a 38" cut will fit through a 42" gate I would take a tape measure with me to verify though.
/ Best lawnmower #10
I want a cub cadet
ZTR or lawn tractor? Side discharge, mulch, bag, or all three? I bought a new Cub Cadet lawn tractor in 1995 and traded it off in 1999 when I didn't need it anymore; pretty nice little machine and I can't say for sure, but I think it was 38" cut. You might be able to get through a 42" gate with a mower with a 38" cut, but you might not, too. I think it may depend on the discharge chute and how far it sticks out, although you may be able to fold it up to get through a gate. This year Toro came out with a ZTR with a 32" cut and with the side discharge chute that I use most of the time, I can barely get through a 36" gate. When I put the bagger on, I can't even get through a 48" gate. However, it is pretty quick and easy to install and/or remove the bagger.
/ Best lawnmower #11
I think a Cub Cadet is a risky choice. They have quality problems in my opinion. I own a CC garden tractor.
/ Best lawnmower #12
Wish things were as simple now as they were in my day. There was only one choice in CT back then: a walk behind Locke. If you wanted to ride, you could put a sulky behind it. You could read a newspaper and steer with your feet if you had enough open space. Those machines lasted 40 years for many people and the 75 inch machine could probably fit through the 42 inch gate with the gangs all the way up. The 70 incher certainly would have. I think they still make them, but from what I've heard the quality went out the window in the 70's some time. Today's mowers could never, ever manicure a lawn like those gang reel mowers did. And, at 75 inches, you could cover a lot of ground at a very comfortable walking speed. Of course they were bears to maintain - you couldn't sharpen them yourself without a shop full of tools, and if you hit a rock, you could be in big trouble. Those were the days when cutting grass was a pleasant job.
From what I've seen, the Cub Cadet mowers are pretty much light duty stuff designed for the consumer market. I'd look to the well known pro machines for a business - Kubota, Scagg, Yazoo/Kees maybe Ferris if they make 'em, etc. That 42 inch gate really cuts into your profit potential - as someone else mentioned above, I'd consider replacing the gate before buying a machine. If you want to save money, I'd go with a commercial walk behind first and when your profits permit, maybe upgrade to a commercial quality rider.
/ Best lawnmower #13
Nfaile said:
I want a cub cadet
I'd personally stay away from MTD, I also have a White GT 21hp 48" that I would like to drive off a cliff if I didn't have the bagger and electric sleeve hitch.
/ Best lawnmower #14
I maintain a fleet of equipment for a landscape company here in town. Case back hoe, Case dozer, 2 dump trucks, ZTR's, ect.
Ferris is by far the best in my eyes. They have had them all and the Ferris with a Kawasaki engine is hard to beat. Scag would be my second choice or Bad Boy. Last thing in the world I would buy is a Cub Cadet. What a POS. They had 1 and it broke everywhere possible. Stamped decks, which it had were the main sore spot.
I will put it it this way. For every 50 hours the Ferris runs I spend 1 hour on maint. This includes grease, oil, blades, ect. Scag is about 1 hour for every 40 hours. Dixon they had were about 1 hour per 25 hours. Cub Cadet was literally 1 hour per every 4-5 hours.
Chris
2025 Swict 84in. Bucket Skid Steer Attachment (A61572)
2025 Swict 84in...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2015 Chevrolet...
2022 Case 5550 Trident Spreader LOW HOUR (A63688)
2022 Case 5550...
2015 Peterbilt 337 Galbreath CH8000 Container Handler Truck (A64194)
2015 Peterbilt 337...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2019 Caterpillar 349FL Hydraulic Excavator (A61572)
2019 Caterpillar...
