Power Trac Future
/ Power Trac Future #21
Look under New Attachments link in the middle of the PT webpage:
NEW
The Utility Grapple is the most useful attachment I use during non-winter months. In addition to carrying brush piles it can grab just about anything you can think of. Much more useful than a grapple bucket.
I would LOVE a utility grapple. PT charges $800 plus shipping for these. Gotta save up!
I would also love a 'grubbing bucket', which PT doesn't product, but is basically a really small bucket, mounted just like the regular light material or rock bucket, that is used for digging up stuff - it is a replacement for a hand shovel.
Sincerely,
Rob :)
/ Power Trac Future #23
Sincerely,
Rob :)
Look at this. You might even be able to build one.
http://www.northerntool.com/shop/tools/product_200356534_200356534
http://dai.ly/oUxMcP
http://www.youtube.com/v/Cbcezo8R8mE&rel=0&hl=en_US&feature=player_embedded&version=3
This one is $129
https://www.foryourshore.com/index.cfm?carttoken=P94XQ2H080711014956&action=ViewCategory&Category=33
/ Power Trac Future #24
Thanks so much JJ, you always have something interesting to show or say. Much appreciated.
Looks like I'd have to get the bucket model... I don't think that it will fit on the PT's non-adjustable forks?
-Rob :)
/ Power Trac Future #25
for sale in WI
extreme brush mower
I'd consider getting it, but the lift is a bit anemic for the size of machine.
anyone know if you can just put the loader tires on it and beef up the lift arms and hydraulics or is it an entirely different chassis etc?
karl
/ Power Trac Future #26
Sure you could beef it up , but can the wheel motor shaft take the extra weight.
The lifting force has a safety factor built in so if you lift the rated load, the rear end will not come off the ground. You could load the rear end down and lift more, but you do it at your own risk. The hyd can do the job, and you could up the relief pressure, but you will have to know all the specifics to do all this.
/ Power Trac Future #27
Ok I like that idea. Back hoe costs to much for me right now and I really don't need something that extravagant but I wonder how hard it would be to fabricate/make one fit a PT 425. A strong quick attach plate and a way for it to mount to it. Probably a smaller digger version so as not to overwork the tractor. Hmmm ideas anyone or has anyone made one yet for the PT 425? Don't be afraid to chime in.
/ Power Trac Future #28
You could make a smaller one of these.
/ Power Trac Future #29
Or you could take a minihoe and figure out some way to flip the bucket around. Wouldn't that essentially be the same thng?
/ Power Trac Future #30
Some nasty leverage would be trying to tweak your loader arms. I am not sure I would want to try that.
Ken
/ Power Trac Future #31
I built a ''grubbing bucket'' similar to the one J J showed in the thumbnail, but mine does not have teeth and is shaped similar to a shovel I use mine on a 425, it sees more use than the mini-hoe, I used a frame cut-off from a international semi roughly 11'' wide and 20''long 5/16-3/8 thick steel, the frame rail had to be cut with a plasma cutter, if I can find the original pictures I will repost them, eventually I plan to add a grapple to this bucket next summer just have not had time yet to fabricate
/ Power Trac Future #32
Here are some pics of grapples on a stump bucket.
Also a slide on fork grapple.
/ Power Trac Future #33
JJ- can you include links to where you found the photos? It would help us out.
Thanks,
Peter
/ Power Trac Future #34
These are photos that I have saved over the years.
One of the best tricks to get the label or manufacture, is to use Google and do an image search for tree spades, stump buckets, etc. I have heard they even have a search that you show a picture, and they try to match it with a name or site. etc.
http://www.paumco.com/quick_spade.htm
http://www.tractorbynet.com/forums/power-trac/131941-tree-spade-3.html
Will try and list the manufacturer as I find them.
I have to add, these things are expensive, and I posted them for reference if you wanted to build something similar, and they are on Ebay also.
If you draw the spade up, a metal fab shop can cut, and bent it for you and you weld, or they weld.
Meyers Built Skid Steer Loader Attachments: Skid Loader Attachments Tree Spades MeyersBuilt Tree Spoons
http://www.attachmentscjj.com/html/tree-spade.html
Most anyone should be able to make this shovel.
http://www.attachmentscjj.com/html/pallet-fork-spade.html
/ Power Trac Future #35
Hello;
Would one of you fine fellows provide me with a phone number for Power Trac. For the last three days there web site has not benn able to be accessed.
thank you, nicholas
/ Power Trac Future #37
I suspect that the thunderstorm last weekend is still affecting them (took out power to 20 million customers over 10 states). We finally got our phone lines back yesterday in VA, so they could very well be one of the many still without power and phones. Give it a few days.
http://bdtonline.com/local/x2004678...f-residents-in-two-Virginias-remain-powerless
Also, being the small company that they are, they probably shut down for a few days around the 4th of July anyway, so you might not get any response until Friday, regardless of when their power comes back.
/ Power Trac Future #38
I also recall that the entire company takes a month off for a European style vacation each summer.
/ Power Trac Future #40
I just received an email from someone who lives in Tazewell and son works for Power-Trac. They are on summer Vacation until Monday 9 July 2012.
213090 (A64276)
213090 (A64276)
Sunflower Yard Art (A64557)
Sunflower Yard Art...
1995 T800 TRI/A DUMP TRUCK TRACTOR (A67148)
1995 T800 TRI/A...
2026 SDLANCH SDLMG1220F Galvanized Metal Livestock Shed (A64194)
2026 SDLANCH...
2021 Bobcat UV34 4x4 Gas Utility Cart (A64553)
2021 Bobcat UV34...
2025 DOWN 2 EARTH GOOSENECK TRAILER (A65054)
2025 DOWN 2 EARTH...
