Rotary Blade Assembly Removal
/ Rotary Blade Assembly Removal #1
fenneran
Staunton, VA
Kubota L2900
I have an old (I mean OLD) 5' rotary mower someone gave me. The transfer case is loose and I keep breaking shear bolts, so I need to take it off and replace the bolts (and sharpen the blades while I'm at it).
I've got it up in the air and removed the center shaft bolt with an impact wrench.
Now what?
Nothing will move. I've soaked it with WD40 and smacked it incessantly with a sledge hammer, but the assembly (big round plate and blades) will not budge.
Any ideas?:confused2:
/ Rotary Blade Assembly Removal #2
The big round plate you refer to is generally called a stump jumper, as its purpose, besides mounting the blades, is to guide the cutter assembly over obstacles, rather than let the blades hit them full force. More than likely the gear box shaft has rusted to the stump jumper, particularly if the mower sat for a long period of time.
If, and i stress IF, there are a pair of holes in addition to the center hole, you may be able to loosen the plate with a large puller, however don't pull on the outside edges of the plate or you will surely bend it.
Lacking that you can try some heat with an oxy/acetelene torch around the gear box shaft on the stump jumper plate in hopes that will break the rust bond between the plate and shaft. Don't heat the shaft directly though as too much heat would take the temper out of the metal.
Note too, removing the blades before pulling the stump jumper will make the whole operation easier, and they'll need removed anyway for ease of sharpening.
On the subject of breaking shear bolts, its possible too, you are mowing such dense material the mower is overloading thus causing the bolt to shear. While the gearbox mounting bolts do need to be tightened/replaced, this may not end your bolt shearing issues.
Thanks Charlie. I do not see any additional holes besides the middle one, so a puller is out. I may try and get a buddy's torch and try that and see what happens. Taking the blades off may prove tricky as well...everything has been sitting and they are pretty rusted as well.
The center nut was a 1.5", and the blade nuts are bigger. venture a guess as to what size socket I need to go get?
/ Rotary Blade Assembly Removal #6
Had the boy go check our bush hog he told me it.s a 1-3/8 nut. hope this helps. Paul
/ Rotary Blade Assembly Removal #7
We have a 5ft Bush Hog the blade nut size is 1-3/8. I do not know what brand or size your cutter is. Any way I hope this helps. Paul
It has to be bigger than that because the 1 1/2 socket is too small. I found a friend who has a large socket set that we're going to use and hopefully get them loose. Thanks!
/ Rotary Blade Assembly Removal #9
No problem Frank am sorry I could not be of more help. Have you been able find out what size cutter and make you have? Tid Bit: am from VA originality ment to look up Staunton am from Blackstone Paul
Paul, Its a 5' of unknown brand :).
Staunton is at the intersection of I-81 and I-64, West of Charlottesville in the Shenandoah Valley
/ Rotary Blade Assembly Removal #11
Hi" Frank, Any chance of a picture of the cutter maybe I could ID it. My oldest is in the service and was in my home town last week he stopped there on his way to jump school in NC.with the 82 Airborne and ask me why I ever left cause it was so nice and never went back he really liked the area. Paul
Sure. Here it is:
/ Rotary Blade Assembly Removal #13
The tailwheel assembly and gearbox kinda resemble an old modern/sunshine cutter.
/ Rotary Blade Assembly Removal #14
when you say transfer case is loose.. do you mean the gearbox wher eit bolts tot he deck is loose? or is the input shaft to the gearbox loose?
also.. wd-40 is for removing stickerts from glass.. it's not a penetrant.. not one i'd use anyway.
pb blaster or kano labs kroil is a better product.
ps.. don't heat that lower output shaft unless you plan on replacing the lower seal in the box.
soundguy
soundguy
Soundguy,
The four bolts holding the gearbox are loose, and won't tighten. You can grab the gearbox and wiggle it in place. The guy who gave it to me said it had been sitting in a field for a "long time", so everything is rusted together, I'm sure.
Will look up the two products you mention. Thanks for the tip.
/ Rotary Blade Assembly Removal #16
if the bolts threaded into the casting and are wallowed out.. then longer bolts and nuts will be needed
soundguy
/ Rotary Blade Assembly Removal #17
Sure. Here it is:
Hi" Frank,:thumbsup:
Sorry it took me some time but I was a little short but thanks to the picture I think I found it I think if you check into you will agree. It was made by a company by the name of HOWSE....Seem the front 3 point are a distinct kind. Paul
/ Rotary Blade Assembly Removal #18
Frank,
They said there is a decal on the rear deck with the model and serial number on the rear top deck ??? I would call them as the diagrams they show are for newer cutters than yours anyway all the info is on there web site I just typed in the Howse name and was directed to it . You know if it were not for the front 3pt. I would say it was a bush hog like my unit.
hope this helped. Paul
Thanks Paul, I'll have a look tonight.
2017 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2017 DRAGON 150...
2014 TIELKE TRAILER 20 FLOAT UTILITY GOOSENECK TRAILER (A58214)
2014 TIELKE...
2006 International 7600 T/A Flatbed Truck (A60352)
2006 International...
SDLL30 skid steer with bucket (A56857)
SDLL30 skid steer...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
Truck Tractor (A61568)
