ford rear axle code chart?
/ ford rear axle code chart? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
i'm going to look at a 4x4 99 F350 later today.. anyone got an axle code chart i can print so i know what rear end ratio is?
IE.. my 04 F250 is a 'C1' whish is limited slip 3.73.. etc...
thanks
soundguy
i'm emailing to get the axle code off the door jamb.. thouhg could ask for the vin too.. I know i have seen an axle code chart somewhere.. not sure about checking via vin though.
soundguy
well that narrows it down to 3.73 or 4.10
soundguy
/ ford rear axle code chart? #6
Simply put if it has a letter first it will be limited slip. I would walk right then and there if it does not have a LS.
Chris
/ ford rear axle code chart? #7
Some 99s had the 4.30s, I think mostly duallys and V-10s. Be careful with the limitslip axle. I found out on the ice when my 01 went sideways down a icy hill. I still miss it :(
/ ford rear axle code chart? #8
It may be too late by now, but there should be a tag on the rear axle housing with the gear ratio stamped on it.
i found a chart online that decodes the door jamb code.
looks like 4.10 and 3.73 are the 2 popular ones for a 99-2003 7.3 psd with an auto trans.
soundguy
/ ford rear axle code chart? #10
soundguy
9 times out of 10 it will be a 3.73 if its a F-350 SRW or a F-250. About the only time you see 4.10 gears is in a F-350 Dually. This is not a rule by any means but its how you see it 90% of the time. Again, if you have a letter infront of the number on the axle code its almost certain to be Limited Slip such a s C3, ect.
Chris
yep.. the one I looked at was f2 limited slip, 4.10 and was a dually.
it didn't work out.. had too much rust.. was a northern truck.
almost went to look at one todday.. but turned out to be a 2003 6.0psd.. not a 7.3
darn... had low milage and looked decent in pics too.. :)
soundguy
2003 HRTO 14ft. Enclosed S/A Trailer (A61574)
2003 HRTO 14ft...
2017 CAT TL1055 (A60462)
2017 CAT TL1055...
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2017 Chevrolet Express 3500 12FT Box Truck w/ Liftgate (A61573)
2017 Chevrolet...
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
