throwing belt
/ throwing belt #1
ohioelcamino
hello all i hope someone can help me. i have a 32 inch walk behind snapper and it runs and cuts great, but my left side drive belt wants to come off when ever it goes backwards regardless if your pulling back or the trans is moving it back. i have checked all the pullys and such for excessive play but it all appears normal. i hope someone can help im just not sure why its doing this. makes it real fun coming off the trailer.
thanks
fil shaffer
/ throwing belt #2
I don't know that machine but check the alignment of the pulleys. Make sure they are exactly parallel and perfectly aligned. If one is canted to the other, or there is any stagger, belts will want to leave.
/ throwing belt #3
My Kubota L275 was always throwing the fan belt for a time. It got worse and the belt would invert in the pulley as soon as I started the engine after reinstalling the belt.
The belt looked perfect but a mechanic told me the internal cords can break on one side causing the belt to flip over. I replaced the belt and it worked fine.
/ throwing belt #4
I agree with kco. I would try a new belt. I have a Honda rear tine tiller and a MTD riding lawn mower. When a belt starts giving me the type of trouble you are talking about I change the belt even though it looks good. Usually that solves the problem. Short Game is also right in that the pulleys should not be bent and should be lined up.
/ throwing belt #5
You'd be surprised how quickly you can lose or shred a belt if the alignment is off by a quarter of a millimeter.
"Honey, what's this skinny washer for?"
/ throwing belt #7
If a new belt doesn't help, I would suspect the axis of rotation of that pulley is tilted ...can you determine whether the belt comes off above the pulley, or below it? That would suggest which way the axis is tilted (remembering that you are "reversing") ...and, assuming the pulley spindle shaft is not bent, you might be able to use a shim to correct.
You could observe, perhaps, by REMOVING THE BLADE(S) then elevating the mower (say, on jack stands, or lift w. FEL) and running it in reverse to try and duplicate.
Causes? a force that bent the shaft, and/or deformed the mower's top plate to which the pulley housing attaches (which shimming might be able to correct).
Another thing to try is to install a "keeper" or two, somehow...a "Z" shaped piece of stock (or, two angles fastened together in opposition) ...initially (at least) bolted to allow some adjustment ...making sure all edges are rounded
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
Kubota V3300-T-E3BG Turbo Diesel Engine - 3.3L - 84 HP - 2016 - Tier 4 Interim (A63689)
Kubota...
2021 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A62129)
2021 CATERPILLAR...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
