Mowing Replacement blades
/ Replacement blades #1
Behrend II
Menomonie, WI
LS XG3140H
Hi, I need to replace the blades for my 54" mid-mount mower on my B2400. Do I need to get them from a dealer or can I find them from an aftermarket manufacturer?
/ Replacement blades #2
There are a lot of sources for blades...
If you know how to measure what you need you can get a larger selection,...
Length is measured diagonally from cutting tip to cutting tip, if it is rounded off, allow for the missing material in your measurement.
Width and thickness...
The mounting hole diameter...
Oregon has some great blades, regular, high lift, and mulching....
KennyV
Thanks Kenny, so you're saying that any blades with the same measurements should work?
/ Replacement blades #4
KennyV
That is nice to know. Maybe could be in a sticky for others to find quickly??
/ Replacement blades #5
Are not Oregon blades gator blades?
/ Replacement blades #6
Absolutely...they will work, and you can select the best blade for your use... there are many sources of blades... you just need to know your measurements..
I'm not sure if they are the only source of Gator blades, but they make them, I have gator mulching blades on my 72 inch ZTR... KennyV
New/Unused Landhonor Mini Grapple Bucket (A65583)
New/Unused...
Ford 3930 Tractor (A65579)
Ford 3930 Tractor...
2022 MORBARK EAGER BEEVER 1215 WOOD CHIPPER (A63276)
2022 MORBARK EAGER...
82" X 18' EQUIPMENT TRAILER (A64277)
82" X 18'...
2007 Chevrolet Silverado 3500 4x4 Service Truck (A64556)
2007 Chevrolet...
Wolverine Quick Attach Trencher (A66408)
Wolverine Quick...
