Mowing Replacement blades
/ Replacement blades #1
Behrend II
Menomonie, WI
LS XG3140H
Hi, I need to replace the blades for my 54" mid-mount mower on my B2400. Do I need to get them from a dealer or can I find them from an aftermarket manufacturer?
/ Replacement blades #2
There are a lot of sources for blades...
If you know how to measure what you need you can get a larger selection,...
Length is measured diagonally from cutting tip to cutting tip, if it is rounded off, allow for the missing material in your measurement.
Width and thickness...
The mounting hole diameter...
Oregon has some great blades, regular, high lift, and mulching....
KennyV
Thanks Kenny, so you're saying that any blades with the same measurements should work?
/ Replacement blades #4
KennyV
That is nice to know. Maybe could be in a sticky for others to find quickly??
/ Replacement blades #5
Are not Oregon blades gator blades?
/ Replacement blades #6
Absolutely...they will work, and you can select the best blade for your use... there are many sources of blades... you just need to know your measurements..
I'm not sure if they are the only source of Gator blades, but they make them, I have gator mulching blades on my 72 inch ZTR... KennyV
2018 ALLMAND MP40-8B1 PORTABLE (3) PHASE GENERATOR (A63276)
2018 ALLMAND...
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2023 ANDERSON IFX720 CONTINUOUS BALE WRAPPER (A64277)
2023 ANDERSON...
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
AR500 Coyote Target (A65640)
AR500 Coyote...
