new B2320 is here
/ new B2320 is here #1
displacedPA
Gold Member
SC
NH T2310
Well heres a pic.. thanks all tbn users for ur input.
/ new B2320 is here #3
Are you letting that get wet?!?!? Get out there with an umbrella for her!!! :D Looks great!
Where about in NC???
/ new B2320 is here #5
Congrats !! I have the same model and have been very happy with what it can do .
/ new B2320 is here
Haha it stopped raining so i drove it down to the pole shed... fits in there like a glove... have to let it dry out here before i can really test her out..
/ new B2320 is here
Union county NC is home for now
/ new B2320 is here #8
Nice machine... I have same. Don't forget to grease the loader every 10 hrs, and torque the wheel nuts after the first 5 - 10 hrs.
Be well!
/ new B2320 is here
yea we like it here... Its a nice quite place.. in the woods
good advise on the grease and wheel lugs I will be sure to do both..
hmmm now Ill start reading about what grease is best. Im sure there are lengthy threads about that... :laughing:
/ new B2320 is here #11
Congrats! Just got the same & amazed at what she can do.
/ new B2320 is here #12
Nah, any old red grease from say Home Depot :thumbsup: Re-apply it as often as directed (about every 10 hours) & it won't matter what kind you use.
Nice tractor, BTW :thumbsup:
/ new B2320 is here #13
Congratulations! Nice looking tractor.
Be sure and check the fluid in front drive now and after a couple of hours use. There are cracks and crevices that hide from the fluid on initial fill and then accept it and scares people when they check it later and find it low. Many blame the dealer for not filling but it's a part of the beast.:thumbsup:
/ new B2320 is here
well I ran the tractor some today and checked the front axle fluid... per JT advice.... ;) looks low on the stick to me... I will have to get some more fluid.. I only used 4x4 when digging up a old root ball on a tree.. I re read my manual it says use UDT or Super UDT or 80 90 wt. as a replacement.. does anyone no know what is in it form the factory??? JT Im sure you know the answer to this... I think you are right on about it being low due to the fact it has to circulate...
I also took the time to tie wrap the hyd. lines a little neater so that they dont hit the side of the hood.
The sun was out all day so I did get some seat time.. I stayed in the woods though... digging and using the BB to level some ground.. great machine plenty of power... I will fill up the axle before I run the unit again..
/ new B2320 is here #15
DisplacedPA , Its my understanding they come with UDT or Super UDT, but I can 't remember which my dealer said . At 400 hr change my dealer recommended 80 90 wt . Keep in mind I live in the hot deep, South where winter is practically non-existent .
If you 're goin' to your dealer for fluids, ask them about original fluid and what they recommend at the 400 hr change for your climate .
Edited to add : be careful about over filling . It probably won 't take much . See fluid quantities in manual .
/ new B2320 is here
Checked the fluid again today it looks low after running a bit today... Im going to go to the dealer after work tom. and ask them about what kind comes in the unit from the factory... I don't think I would have ruined anything in the hour I ran it today..
The first project the wife asked me to do was level the area where our fire pitt is.. I happily went to work as she when off to Costco's I ran out of dirt but made good progress.. I cut down one tree while she was out also. When she returned I said come on down here hun and drive the tractor for me. She drove it and was laughing the whole time as I loaded up the bucket with logs.. We both had a great time... She said Now I know why you wanted a tractor...
:D
/ new B2320 is here #17
:D
Big mistake, you'll never get any credit for doing work now when you drive the tractor.
/ new B2320 is here
Well today I bought a gallon of SUDT fluid today between the front diff and the rear I was 1 quart low. The rear may need a bit more but ill let it sit over night and check the level again.
thanks for the tip JT
/ new B2320 is here #20
WOW I can't believe you did that:confused2:..... You let your wife drive the tractor.... there goes your seat time.:laughing: Now you will have to find a place to hide the key.;)
2018 CASE 650M LGP CRAWLER DOZER (A65056)
2018 CASE 650M LGP...
2016 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2016 GENERAC...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2025 44in Single Cylinder Grapple Rock Bucket Skid Steer Attachment (A66734)
2025 44in Single...
GENERAC MOBILE...
130 BBL VAC TRAILER (A63569)
130 BBL VAC...
