gator 6x4 cluctch vibration rattle
   / gator 6x4 cluctch vibration rattle #1
cmrhunter
john deere 4710
I have a 6x4 john deere gator that has a loud rattle in the clutch area - transmission end. It now has a vibration that increases with rpm. What is the problem?
   / gator 6x4 cluctch vibration rattle #2
me too, ordered a driven clutch, and keeping my fingers crossed it's not the transmission,
spring on the driven clutch it loose when it's stopped, doesn't seem normal.
   / gator 6x4 cluctch vibration rattle #3
Sounds like you both need the Deere tech manual, shoot me your email and I'll send you both a PDF of it
Joe
   / gator 6x4 cluctch vibration rattle #4
I sent you a PM. Thanks for the help
   / gator 6x4 cluctch vibration rattle #5
Had a similar problem on my 6x4 gator--sounded like piston rattle. thought it was a secondary clutch, but finally figured out it was the drive chains slapping because they were loose. Tightened up and greased and now quiet. sounded like a big bucks problem, but fixed with a little wrenching.
   / gator 6x4 cluctch vibration rattle #7
should be there
2015 Nissan Versa SE Sedan (A55853)
2015 Nissan Versa...
UNUSED WOLVERINE MCB-11 48W 48" HYD 4N1 BUCKET (A57193)
UNUSED WOLVERINE...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
2022 JOHN DEERE 318G SKID STEER (A52707)
2022 JOHN DEERE...
EZ-GO Electric Utility Cart (A55851)
EZ-GO Electric...
