JD 790 Front wheel lockup
/ JD 790 Front wheel lockup #1
MinnyMoMan
John Deere 790
Hello everyone am new here. Have searched for a problem I am having with my 790. The left front wheel (as you are sitting on tractor) locks up, mostly in reverse. If you drive forward a little it works fine, then later it will lock again. It is getting worse so going to fix, had the front wheel gear box open at the wheel to look at gears as one thread mentioned but they are fine. So before going any further wanted to get peoples advice. Any knowledge or advice would be helpful, thank you.
/ JD 790 Front wheel lockup #2
You wrote you opened up the front pumpkin and didn't see any problems. That's good...now it's time to pull the wheel and hub (if you haven't already) and see what's going on there.
When I had my 790, I was fortunate enough to have no problems with the front end (which are rare, considering the number of 790's that were sold), so I never had to pull anything apart other then when shimmed the hydraulics and routine maintenance.
I meant i already took wheel off and took that cover off, those gears are fine, have not opened the center trans axle yet
/ JD 790 Front wheel lockup #4
Maybe the first question that should be asked is:
Are the tires the correct size for the tractor. Improper tire size can cause that also.
Tires are the right size, now having problems getting the center hub out, will come out about a half inch but that is about it. Anybody have this problem? Any suggestions? Have had plenty of these out but never one that hung up like this.
Thanks for your help
/ JD 790 Front wheel lockup #6
If I recall, there's a circlip you have to pull before you can take it down. Wish I still had my service manual, but that went when I sold my 790.
Anyway, if no one here can respond wth a picture of the components, you can try JD Parts (https://registration.deere.com/Sign...ontroller.SessionStartup?userAction=fromEmail) and you'll find a number of illustrated break down pictures that might help.
You will have to register, BTW.
/ JD 790 Front wheel lockup #7
MinnyMoMan,
Attached are some pictures from the JD790 service manual on disassembling the MFWD differential and shafts. Let me know if you need more pictures from the manual.
Bruce
/ JD 790 Front wheel lockup #8
Roy, When are you gonna learn how to do it?:laughing:
/ JD 790 Front wheel lockup #10
U have to pull both front axles out. Then the center section will come out. I have just had to rebuild the whole front end on mine about 3 months ago. More than likely one of the gears one the left side hub is broke and a broken off tooth is getting caught in between the gears. That is why it stops turning. Mine was doing this at one time when it broke. Easy to fix just "VERY EXSPENSIVE". Each of the outside gears are close to $90 each. More than likely u will need bearing also, $20 each. If u have a ring/pinion issue, $770 for just the ring/pinion. I am willing to bet u have a broke outter gear. What ever it is, if it was me knowing ? I know by having this exact samething happen to me, I would pull it all apart. Check everything, clean all metal out(it's in there) and replace what needs be. Do not drive tractor anymore or u will be spending more money. Like i said, this has just happened to me and close to $1500 dollars later, with me doing all the work, all is well for now! U need to buy u a shop manual 4 your tractor also. Good info in it. Good luck!
/ JD 790 Front wheel lockup #11
Just wondering, have u had a chance to look into the front-end problem yet?
Thanks to everyone for your help and the pics of the manual. Any pics of the wheel hubs? At this stage I have the whole front end apart and am rebuilding it, the biggest part of the problem was the left front, but since the right was so wore am rebuilding it as well. Just waiting on parts to come in. It was rebuilt before with what looks like the wrong bearings.
Any suggestions on replacing the sleeves on each side? They look like they are going to be fun.
/ JD 790 Front wheel lockup #13
What do mean by sleeves? Not sure what u mean.
/ JD 790 Front wheel lockup #14
MinnyMoMan,
Here are some more pictures from the JD790 service manual on the outer drive and spindle housing.
Bruce
/ JD 790 Front wheel lockup #15
MinnyMoMan,
Here are some more pictures from the JD790 service manual that you may find helpful when you reassemble the MFWD axle.
Bruce
/ JD 790 Front wheel lockup #16
Have u had any luck fixxing the front end yet? If so, what did u find wrong? Just wondering!
/ JD 790 Front wheel lockup #17
Are you referring to the oil seal wear sleeves? I'm not sure if that front axle is the same as the one used in my 955, but going by those pics of the manual it looks viturally identical. The wear sleeves were not really a problem to replace. It's not too bad pulling the old sleeves off, but it can be a bit of a pain putting the new ones back on. The rubber backing does not want to slide easily onto their mounts. A little dab of grease on the rubber part of the sleeve makes life a whole lot easier.
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2023 John Deere 333G Track Loader (A63111)
2023 John Deere...
Case 586E Straight Mast Fork Lift (A60352)
Case 586E Straight...
2017 Ford F-250 Single Cab Pickup Truck (A61573)
2017 Ford F-250...
