How much 2 cycle engine oil can be safely added to diesel
   / How much 2 cycle engine oil can be safely added to diesel #21
Well I dont think bio diesel has made its way to central maine yet so my question still stands
   / How much 2 cycle engine oil can be safely added to diesel #22
Hey MODMECH, I would have to believe, IF it has any Bio content, then it would be posted on the dispenser, BY LAW? I know more products are being sold down here, THAT state NO ETHANOL...So far I Haven't seen any Bio added to diesel, but then I don't go to Truckstops to get my diesel?
   / How much 2 cycle engine oil can be safely added to diesel #23
If the ULSD you are pumping has even the slightest bit of "Bio" in it and it almost certainly does, adding anything as a lubrication enhancer is simply unecessary.
The biggest problem with injectors, pumps and diesel fuel systems is lack of proper maintenance. Then people was a "fix-it-in-a-can" and that product does not exist.
True. Even B1 (1% bio) is supposed to match old diesel (pre-LSD) in lubricity.
If any B is added, it must be posted on the dispenser. There is a station here that has B5 at the pump and they are typically a few cents cheaper than the surrounding stations (I know, that is a shocker) so I've been filling there whenever I can. I don't at the 2-stroke oil when I fill there. I also have not noticed a decrease in power or mileage with the B5.
   / How much 2 cycle engine oil can be safely added to diesel #24
Where do you get the info ULSD "almost certainly does" have "Bio" in it?
If you have a source for that info please tell us....I'd love to have 1-2% bio in my diesel fuel, but don't see that happening unless I add it, and I do when I have it. I pick up some B99 and use it as an additive, problem is I can only get it 150 miles away, in Asheville NC. When I don't have it, I use 2 stroke oil. BTW the B99 does NOT store well, starts smelling a little rancid after a few months.
   / How much 2 cycle engine oil can be safely added to diesel #25
Skyco,I agree on not finding any Bio here either, but could you explain B99? Plz.
   / How much 2 cycle engine oil can be safely added to diesel #26
B99 is biodeisel that is 99% bio. 1% is still fossil feul. My guess is for some property?
The number after the B is the bio content. Kind of like Ethonol. E85, E10, E15 etc.
   / How much 2 cycle engine oil can be safely added to diesel #27
Remember adding trans fluid to road fuel will make it look red like off road fuel.
Mike
So if you get dipped you can just say you poured some ATF in it and its not red dye??:D
   / How much 2 cycle engine oil can be safely added to diesel #28
Thanks, I has assumed that was the story behind it? We don't have any"B" around here. So people are home-brewing, and i have a friend that is french-frying his Benz, with justa final filter. I feel like it will stall out this winter?
   / How much 2 cycle engine oil can be safely added to diesel #30
This would be expensive, if they believe it is off-road fuel....Don't know how much atf it would take to dye it?
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A51222)
LINK BELT LB-98...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Set of AG R4 Wheels and Tires (A51039)
Set of AG R4...
