Tiller Need help w/ my tiller
/ Need help w/ my tiller #1
TxFig
Member
Texas
John Deere 3032e
This is my first post to this forum. Be gentle.. :licking:
I have a PTO driven tiller that I had to have some work done on (the frame was breaking and had to get it welded). In taking it apart, I ran across another, potentially more serious problem - but I'm not sure. Therefore, I am including pics in the hope someone can guide me a bit.
The first 2 pics are just of the tiller, to give an idea of what it is.
This one is the only markings which give an indication of the model number:
Now for the problem: I think there is a broken piece (or if it's not broken, I don't have a clue how it attaches) in the gear box on the side:
See the slotted bolt? I am pretty sure that this next piece goes in there somehow...
To follow-up:
(1) Any idea what make/model tiller this is?
(1b) Any idea where to get a parts diagram?
(2) how does that (I assume) broken part attach?
/ Need help w/ my tiller #3
I can't help you on the model number or make, but I can give you some info on my rototiller. On mine, there is a post in about the same place as yours with a gear on it. The post can be moved so that the gear takes up the slack in the chain so the chain doesn't jump off the other two gears. I can only assume that the curved piece of steel you have somehow rubs against the chain in such a fashion to accomplish the same thing. The curly thing might be some kind of spring to keep the tension on. Hope this helps.
/ Need help w/ my tiller #4
quick google search comes up with Agritec Tiller (Model AT20120)
/ Need help w/ my tiller #6
I'm not familiar with all the different brands of tillers, however i'm somewhat experienced with chain drives on farm equipment.
It looks like a broken chain tensioner. The D portion fits in the slotted fitting, and the curved portion (It should be all one piece by the way) is adjusted to take most of the slop out of the chain. There should be a pin or perhaps a set screw to hold the D portion of the adjuster in the slot. It needs to be held in by some method at least.
I'd guess theres a nut on the back side of the slotted bolt that you can loosen and adjust the curved portion of the part to run against the chain to take up the slack.
Rather an unusual adjuster that i've never run across before, i've never seen a metal cam such as this for an adjuster. Usually they will be an idler gear or a wooden block to help prevent excessive wear.
It looks like, lacking a parts book, you'll have to have the two pieces welded back together and determine how its held in the slotted bolt to allow adjustment.
Wow - that was a fast response! :thumbsup:
Yes, a tensioner for the chain makes sense (and yes, there is a bolt on the other side to adjust it).
The funny thing is, I really don't think it's even necessary. When the drive shaft is attached, the chain is fairly tight to the teeth (in fact, it's pretty much impossible to get off without disassembling it entirely). I can't imagine that the tensioner is actually doing much...
/ Need help w/ my tiller #8
It is doing some though. When your chain is rotating the motion pulls the chain away from the gears so the tensioner is there to ensure that no gears will be damaged y the chain and to keep teh chain from excessively wearing the gears or vice verse.
/ Need help w/ my tiller #9
To me it looks like the small part and large part were one piece acting like a spring with the long part pushing against the chain. I believe the chain cover held the broken off D in the slot. To assemble the spring tensioner, the slotted bolt was loosened to allow the D part to slide into the slot. Then, the slotted bolt was turned to press the tensioner part onto the chain then locked down.
The D part broke off due to the stress point from flexing being there.
Don't know for sure but I believe I am right.
/ Need help w/ my tiller #10
I have a KMC with the chain drive like yours. The design is almost identical, where you have your slotted shaft I have achain tensioner that extends through the frame with a spring attached to provide tension. I wouldn't be surprised if this is what you have.
Alright, so assuming I do need the tensioner arm replaced (it seems to be far too light-weight to be welded back together), does anyone have a place that I am likely to be able to get a replacement part?
/ Need help w/ my tiller #13
You should visit you local ATV/motorcycle dealer, should be able to fix you up with a suitable bolt on part that will do the job.
/ Need help w/ my tiller #14
His type of adjuster has been common for quite a few years now. They did away with the wooden blocks, and switched to the tensioner in his pics, and started using a 'fiber block'. The fiber block lasts longer than the old wooden design .
EDIT: For the op............picture your curved piece, like a brake shoe on a car............that's what it originally looked like. Without it.....it will rip the teeth of the gears eventually, repair it as soon as possible.
/ Need help w/ my tiller #15
I'd sure try and get the tensioner back on properly because whether it looks like it's needed or not, as the chain stretches with age and use, it will get slack sooner or later and the tensioner is needed to compensate for any slack it might get.
2016 John Deere 1775NT Planter (A63109)
2016 John Deere...
2004 Mack CL713 Tri-Axle Heavy Haul Truck, VIN # 1M1AD64Y04M001417 (A61165)
2004 Mack CL713...
2018 Kenworth T880 Quad Dump (A62613)
2018 Kenworth T880...
(APPROX.18), 40"X159" INSULATED PANELS (A62131)
(APPROX.18)...
COVINGTON IR PLANTER (A62130)
COVINGTON IR...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A61165)
2023 Ford F-350...
