Saving the pond, erosion control project
/ Saving the pond, erosion control project #1
RedRock
Texoma
Mahindra 2816 Gear
Inspired by the works of EddieWalker and jinman, I've decided to start a thread on saving my man-made pond here in North Texas. Here in Eddie's thread I posted some pictures of how the pond looked when I bought the place, freshly dozed and tin horns in place. EddiesLake
Right now my main problem is that the rain itself causes immediate erosion around the end of the tinhorns so I put some crude erosion control measures into place using burlap, mulch, grass and some stones to hold the burlap until the grass can get better established. Over time, I'll probably add more dirt and contour the areas around the water entrance and exit using the FEL on my tractor.
Here's a shot of the entrance for overflow, second and third picture is where the water exits on the other side, last picture is where the water flows down into what used to be the continuation of the creek, but is now the other side of the dam, this is a very steep and deep drop off, at least 15ft. down from where the photo is being taken from. I'm pretty concerned about what might happen in this area if there were sustained rains for too long. So far I've been able to repair it using my tractor after each rain.
Drop off on other side of dam, from above
from below
another unique angle
/ Saving the pond, erosion control project #4
Very beautiful land.
I owned 80 acres in Arcadia, OK for a while and it had a 20 wide by almost 20 foot deep creek that flowed North into the Deep Fork River. There was serious erosion at one point that I was able to fix. At times the creek was over flowing especially when the river would be so full the creek could not flow into it. Sold it when I experienced Adverse Possession by a neighbor when I surveyed and installed a fence with her initial agreement!
Thankfully we found a 112 acre piece near our home in VA. We plan to put in a pond and looking at yours plus the discussion was good. Thanks for sharing.
Jim
/ Saving the pond, erosion control project #5
For a while raw land around Arcadia was selling for an absolute premium. That has all stopped now.
As for erosion, Google "grass Pavers" or "Turf Pavers." There are several different manufacturers and once the grass takes hold, they do a good job. No ruts when you drive over them with heavy equipment in wet weather.
/ Saving the pond, erosion control project #6
From the looks of your video, I'd say that the swale leading into your pond has been filled with dozed cedar and oak to provide some level of filtraton for the incoming water. Because the trees were just pushed in without being cut up, they don't provide a substantial barrier to stopping silt like a series of hay bale dams would. Frankly, the cedars are just stopping you from being able to prepare the area and plant grass or other vegetation in the area. A wet area full of cattails would probably provide better erosion control than those cedars. If they could be compressed into much tighter piles, they might actually help, but it seems to me they are just in the way for working the issue at the moment. That's how I see your inlet issue from just a very cursory exam of your video.
When I look at your culvert horns, I just want to start collection all the softball to football sized rocks I can find and put them at the sides of the culverts where drainage from the road/dam is starting to create erosion at the edges. This insidious erosion will eventually work its way back across your dam and completely wash out your horns. You have to stop that action and I don't know of anything better than small stones except maybe some stones and a bag of sakrete poured around them so it will set up and hold them in place. As Eddie did, some people stack bags of sakrete to the sides and make a flare around the ends of the horns to stop erosion. I think the best solution is a compbination of both concrete and rocks.
It's also obvious that a lot of silt seems to be coming through your horns from the pond. Is that right? The outlet side looks like material is building up there and I'm just guessing it is coming out the horns. It might be washing down the sides of your outlet swale, but I can't tell for sure. I would dig that area out and try to get some rock in there. If you don't have rock, maybe you could get some old busted brick from a construction site. I like scrap brick as a material because it is such a great size to work with and can be easily hauled/handled. It will soon fill in with silt, so that it doesn't look trashy for very long, even if it seems that way at first.
. . . just my ideas from a first look. Eddie will surely have more or better suggestions.
Jinman, yeah you're right about the big trench, it's a big cluttered mess at the moment and will take a lot of work to clean up and make presentable someday. Thanks for all the other tips, I'll be implementing some along the way.
/ Saving the pond, erosion control project #8
I second what Jinman said about the rocks around the culverts. Attached is a pic of the rip-rap I added to mine. What you see came from the removal of a sidewalk behind my house that I repoured. These pieces came from a 3'x15'x4" slab. I've since added a bit more and busted some of the bigger pieces into softball or slightly larger size. They bust real easy with a small sledge hammer. I've also used readi-mix bags around a couple of smaller culverts (8" dia) to reduce erosion. Just keep an eye out for people repouring their drives and porches, etc. I'm sure the contractor would love to let you take a few pieces of slab.
Sorry it's been so long since I've updated my thread here, I'm going to post a few updated pictures but I'll try to take some more current ones this weekend. Basically, I took the advice and started collecting some concrete chunks, brick etc. to help with the erosion. As you can see in this pic(albeit not a very good one) I've added some chunks of concrete around the tinhorns of the pond spillway... I'm using my pump to try and battle the drought here in N. Texas
/ Saving the pond, erosion control project #10
Good to see you are back Sandusky. I'll be lookin' forward to more photos. You just can't look at too many photos of water while in the middle of drought.:)
Here are some pics of what I've done on both sides of the spillway where the tinhorns are placed, this and the grass seem to be doing a good job so far. One pic is that of the long flat spread the overflow takes before it turns the corner and drops into the deep ravine (where I have other erosion challenges ahead) This same ravine is what was damned up to create the pond. As a special treat for jinman, I'll add a video link for the catfish feeding that live in it. :licking:
‪catfishfeed‬‏ - YouTube
/ Saving the pond, erosion control project #12
Thanks for the video, Sandusky. We just fed our catfish this morning. They heard us coming and were patrolling the bank, going back and forth in a feeding frenzy. When my granddaughter pitched out the first scoop, it was instant chaos. About 40 fish converged on the same 4' x 4' area and inhaled the food. With subsequent scoops pitched in different spots, it became a fish race to the new spots before competition arrived. Fun stuff!:D
So here's the scenario I'm more worried about because of the drought conditions we are still experiencing. If a thunderstorm happens to dump a lot of rain in a short amount of time, I have a feeling what little topsoil is under these trees is going to wash right down the hill into the pond. Now don't get me wrong, we really, really need the rain, but I don't have the time nor resources to plant a lot of ground cover...it wouldn't even live in this drought.
I'm thinking the only thing I can do is use a combination of sticks, branches, stones, old cut-up rotted fence posts, etc. in strategic spots up this hill. Ironically stuff Ive spent several months picking up.
/ Saving the pond, erosion control project #14
Nature puts willow trees in similar areas for erosion control so the sooner they can be established the sooner control will be effective. Although I've never had the need to, I've read that willows can be started from cuttings but it seems that will need to be tried in early spring or late winter. Although grasses often look more appealing, trees and shrubs excel in erosion control. Good luck with your erosion control.
/ Saving the pond, erosion control project #15
What you can do in dry weather is build terraces. Terrace around areas where erosion might be a problem and then put rocks at the end of the terraces to keep the heavy flow from rutting and eroding at those points. If you let water go where it wants, it will create many ruts, so you terrace to control flow and protect only the areas of high flow around the ends of the terraces. that's what I've done in many places on my property and it works well. A large gentle terrace will also be easy to mow and maintain without hurting the trees due to too much fill in the root zone.
