cable across driveway-
   / cable across driveway- #1
Western NY
MF 596 FEL
Hi,
I'm building a driveway (the driveway goes through dense trees/brush-- so no entry other than driveway) and want to put up some type of effective chain/cable/gate-- there have been ATV's on the property--and I don't want anyone on the property without my permission--I still believe in private property. (guess I'm pretty old fashioned in that regard!).
I was thinking about just posts with a cable across the 17 foot driveway, but it occurred to me that while this would keep out trucks etc, it might be possible just to lift up the cable/chain in the middle and drive an ATV under it.
Would appreciate other ideas-- i know a full gate would work-- but is there something less expensive that some of you guys have tried?
Thanks,
Bob
   / cable across driveway- #2
I hate to be a pessimist but years ago we locked one end of a real strong chain to an old piece of 6 inch steel pipe with about 4 feet buried in the ground and wrapped the other end around a 30 in diameter hedge apple tree. (lots of thorns to deal with.) The thieves cut the lock on the end with the pipe and cut the tree down and stole the chain. A neighbor to that piece of property had trouble with ATVs knocking a fence down so they could run around his five acre yard at their pleasure. He got tired of putting the fence back up so the next time they came he fired off a couple of shotgun blasts straight up in the air and has not seen them since. I think maybe they finally got the message that the No Trespassing signs included them.
I will be watching this post to see what advice you get. It is a good question.
   / cable across driveway- #3
How about running your cable thru a 2" pipe in the middle that goes into a larger pipe in the ground in the middle like a socket. If you can make it long and deep enough, it can't be pulled out when the cable is locked and tight but loose when you take your lock off as the cable will slide thru the hole in your middle support.
beeforty Sounds like a good idea, but couldn't a trespasser/thief just lift up the middle pole-not out of the ground but just up 10-20 inches and drive an atv under the cable on either side of the middle pole??
Thanks for the idea.
Bob
   / cable across driveway- #5
One thing to think about is liability. I know, I know, people hate hearing this BUT, with all the ambulance chasers out there you don't need to be tied up in court till you retire.
With a cable, chain etc across the road it at some point become invisible. A person could possible ride up to it a 50mph and get decapitated. Sadly the persons family will come after you for one of 100 reasons. Sure you may win the case but it will cost you or your insurance company dearly. Orrrrrr, you could lose the case, no one ever knows.
If a gate cost a few buck more it will be worth it in the long run.
Side story. When I was 16 I worked late at a college. One night after leaving my shift the security pulled a gate across the road I always exited from. It was a 2" pipe type about 4' off the ground. It was midnight and I never ever saw that stupid thing. Most of all I never expected it to be there as it never was in the past.
I hit that bugger going 35mph and you can imagine the damage to my parents car.
   / cable across driveway- #6
I would put a center post in as well. You could put a locking pin in it to keep it from being removed from the socket.
I would also place a BIG "no trespassing" sign on the center post so people would see it. You could also hang a couple signs off the chain/cable to call attention to them as well.
Face it, all you are doing is keeping honest people honest. If they really want to get on your property, they will find a way! All you can hope for is to make it inconvenient to get on your place, so they will find it easier to go somewhere else.
If you want to ramp it up a little, install a fake (or real...) camera focused on the cable. If fake, make it obviously visible. If real, put a fake decoy out and hide the real ones :thumbsup: That way you at least get pictures (for future use) of whoever takes the time to mess with your access point.
   / cable across driveway- #7
I would go ahead and bite the bullet and spend some money to put up a gate that was heavy duty and see how that holds up. As mentioned, if vandals want to get in bad enough, they will find a way.
We have a couple gates at my hunt club that are quite ingenious in the way they lock. The padlock actually locks to a pin going through the tongue of the gate arm inside of a piece of heavy schedule 6" dia pipe. NO WAY can you get any bolt cutters on it to try and cut it off. If I was close to the gate, I would take a picture and post it here but it's like 70 miles from me at the moment. If you want a pic, I can take one next weekend when I am up there.
   / cable across driveway- #8
Fences and signs only keep out the honest people. Put up a trail camera and get some pics.
   / cable across driveway- #9
Before putting a cable or something of that nature across a road, I too, would check into the liability of such a device. I think I would bite the bullet as well and just put up a gate. But, that is just my thinking on it. :confused2:
   / cable across driveway- #10
We use the gate to keep teenagers in...When they have a party they then want to drive drunk..Of course on occasion one of them drives into it, messing their car up, just when `escape` is so near....They have to replace or fix the gate as further punishment....Our gate is a heavy pipe affixed to heavier pipe sunk in concrete..Tony
   / cable across driveway- #11
one possible option would be to have two cables/chains crossing the road and then tie the two cables together at three or four points (think multiple horizontal "H"s). this way there would be no lifting the top cable/chain to get by.
to prevent liability or at least reduce it drastically, put up signs 50' and 100' from the gate stating "cable across road". then hang reflectors and reflecting tape all over the cables as well as a huge stop sign. in most areas, this would be enough warning to generally prevent liability.
another option, if you don't want to install a full blown gate, would be a single heavy pipe type gate about 3' high. same idea w/ reflectors, etc.
Thanks for all the tips/help.
Maybe best to just get the gate and try that.
   / cable across driveway- #14
I would forgoe the gate and chain all together, spike mats and nobody gets hurt, they are still there when the cops get there.
   / cable across driveway- #16
Actually, the gate is not really there to keep people out. It is there to protect you from the liability of people hurting themselves or others while they trespass. Thats what no trespassing signs are for too. I have three roads into my 40 acre tree farm. I am not particularly concerned about folks being there doing something productive (berry picking, hunting, running their ATVs) than I am of people dumping (garbage dumps don't seem that expensive, to me anyway, after I pick up the trash and haul it off for proper disposal).
I put up three "gates." Two were ecoblocks (those big cement things that look like legos) with cable strung across them. Local lore is that you hang a PVC pipe in the middle so that someone running into them can't claim damages because they couldn't be seen. The third was made from four inch PVC sunk about a foot and a half in the ground with a 8 foot heavy duty t-post driven down through the pipe, eyebolts wired to that at the top for chain and then filled with cement. The eco blocks were about three times the cost of the posts. My experience to date (four months running) has been: no dumping, one guy I have given permission to pick blackberies, one cable (the shiney new one including the lock) stolen presumably for the metal from one of the eco block gates, and no one through the PVC/t-post gate. The cable on the latter remains in place probably because I fed it down the pipe to ground level and imbedded it in concrete.
So, I suspect if you put out a really nice metal gate it will get stolen for the price of scrap or resale. Rusty is better. I replaced my stolen cable with a bunch of semi rotten logs and rootballs - that has really worked well. When I want through, I just push them out of the way with my FEL and replace them when I leave.
Mf
   / cable across driveway- #17
If you hang a cable and someone gets decapitated, you could get sued out of your pants. Put up a gate, no trespassing signs, reflectors and a game camera if you still have problems.
   / cable across driveway- #18
there are cables and 1 pipe gates all over here.hang a no trespassing sign on it.
   / cable across driveway- #19
Hi,
Thanks,
Bob
Do you want a mental barrier or a true physical barrier?
I have both, both work, the big paper company style gates work best......but I've also used old aluminum cable with t-posts and plenty of posted signs with good success.
   / cable across driveway- #20
Here are pictures of 2 gates that I built and hung on my place. The silver gate is way to heavy to lift off, main frame is 2" pipe. Yellow gate can not be lifted off and is also very heavy, again all made out water pipe. Lock and latch are attached. Lock could be cut, but in 4 years no one has tried. Some drunk or idiot did run into the back side of the yellow gate and deformed it about 10". Am sure it hurt his car / truck more than the gate.:laughing:
More details and close up pictures if you are interested.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
2019 CATERPILLAR 303.5E2 CR EXCAVATOR (A60429)
2019 CATERPILLAR...
2013 Ford Taurus Sedan (A59231)
2013 Ford Taurus...
2006 John Deere 250D 25 Ton Articulated Dump Truck (A59228)
2006 John Deere...
(2) UNUSED 31" X 8 MM EXCAVATOR TRACKS W/ PINS (A60432)
(2) UNUSED 31" X 8...
