Manual log splitter
   / Manual log splitter #1
ametcalf
Central KY
Kubota BX23, Allis Chalmers 5040
:confused:I know that my 12 lb sledge hammer and splitting wedge are not a tractor attachment but because I do not have a hydraulic log splitter I have a question. Is it easier to split wood when it is green or should I let it dry for a year or so first?
   / Manual log splitter #4
Don't know if what we call locust up north is the same as what you are calling it. But good luck splitting locust or apple with a maul. As far as beech goes some will split easily and some not quite so easy. Never noticed alot of difference green or dry.
Think Ill stick to my splitter now, though. Don't think my back could take the maul anymore. LOL
   / Manual log splitter #5
Locust splits easier green, never been around Osage og and beech was the same either way if I remember right, it has only been 40 yrs since I was around those kind of trees. I never was too fond of a sledge and wedge, I always prefered a maul and especially one of those monster mauls(never gets stuck) just be sure to rubber wrap the handle as it is steel and gives quite a bit of shock.
Rick
   / Manual log splitter #6
Splitting wood by hand was relaxing. I liked to use a heavy hammer (single jack) an old hatchet & a couple of wedges. Able to sit down, enjoy a cool beverage :thumbsup:. Since Author Itis moved in I had to give it up and built a log splitter.
Splitting mesquite is best done dry, after it starts to split on its own. Same for eucalyptus and most other wood. Took down a big old China Berry last year, unless hit very hard with a sharp axe or hatchet, things (Maul) just bounce off it.:laughing:
   / Manual log splitter #7
Beech is easier green, apple & locust are never easy.
I do about 4 cords a year by hand even with a gas splitter available at the neighbor's 1/2 mile away. My grandfather split all his own wood with sledge & wedge until he was 92. He always said if he stopped splitting he'd stiffen up and stop moving.
Thank you all for your insight. We have geo-thermal for heat but we have a nice out door fire pit about 50 feet from the house and my friend has a fireplace in his den that we burn while watching basket ball. Not enough wood to justify a splitter but enough to warm me twice as a famous person once said.
   / Manual log splitter #9
I think wood warms much more than that, once when you cut/find the tree, twice when you haul it in, another when you buck it, another when you split it, and stack it, and again when you haul it into the house, Heck with all heat being produced who needs to bother burning it:laughing:
Rick
   / Manual log splitter #10
The northern hardwoods I deal with all split easier green. Mostly maple, yellow birch, ash, and beech. Beech can be a bear. I cut some apple once in a while and don't even attemp to split it usually. I use a 6 lb maul for stuff up to about 12" and go to 8 lbs after that. Then wedges and an 8 lb sledge if it won't crack. I can split a lot of wood with a high speed 6 lb maul. I think a 12 pounder would wear me out in a hurry. Frozen wood splits easier. If I have some tough blocks I'll save them for when it is below zero.
   / Manual log splitter #12
wait until its -25 F and it will all bust apart-no problems
Green & frozen works best for me! 6# or 8# maul. Feel like a young-un after a few hours of that on a clear, calm, 20 degree day!
   / Manual log splitter #13
For those of you that split frozen - are you burning it the same winter or next? I never seem to be far enough ahead to cut & split next year's while I'm burning this year's.
   / Manual log splitter #14
Next. We had our chimney relined this Summer - it was in bad shape and I didn't dare run the wood stove until it was all better. This Winter I hope to recover some of that inve$tment in the chimney by reducing my fuel oil use.
The plan is to consume this Winter what I split and stacked last Winter and to split and stack this Winter what I will consume next Winter. That's the plan anyways. Sounds like who's on first, doesn't it?
   / Manual log splitter #15
"Manual log splitter"....So THAT'S what dad thought I was....I was 16 before I found out my name wasn't "get wood".
   / Manual log splitter #16
I try to start each winter with two years supply in the wood shed. I burn the oldest first. I figure that if something should happen and I can't get wood one year then at least we will be able to stay warm because we're one year ahead. Plus the added drying time dosn't hurt anything.
   / Manual log splitter #17
Gordon I'm surprised you don't stack your wood bark side up . Helps to shed rain , then again could be an old wives tale !:laughing:
   / Manual log splitter #18
Everyone swears by thier own system when it comes to wood - I think it is a way of justifying all the work to yourself :laughing:
I stack it rough like that where I split it to get it out of my way and let the sun and wind get at it for a couple months. During a good dry spell in July I put it in the wood shed. I never noticed the rain being a problem. Only the top couple rows are real wet after a day of rain but they also get the best sun and dry out quick. Bark side up may be better, I don't know. To me air and sun are the most important for green wood. If I needed to keep it dry I would cover the rows with tin roofing.
   / Manual log splitter #19
Rick
Those origional monster mauls were great! I remember being as excited about mine as I was later on about a splitter.. :thumbsup:
   / Manual log splitter #20
Since you are all talking about mauls now, I bought one of these.
A Wel-Bilt Horizontal Log Splitter
from Northern tools.
It's not good for BIG logs, but I put it in the basement (on a piece of tarp to catch the "fines"), drop a log in it, and with some NordicTack motion split the wood while I watch TV and the fire, with a favorite beverage.
This let's me split wood indoors, where I can't swing a maul. It's on rollers and stands up to take about as much space as a golf bag. And I got it on sale about 2 yrs ago for about $90.
Not for splitting 10 cord a year, but keeps my fire fed, and is only a little slower than a maul.
2002 Kenworth T300 TMA Truck (A55973)
2002 Kenworth T300...
Zero Turn Mower (A59231)
Zero Turn Mower...
2014 FORD F-150 STX EXT CAB TRUCK (A60430)
2014 FORD F-150...
1959 DODGE D510 DUALLY FLATBED TRUCK (A60430)
1959 DODGE D510...
2019 F150 (A56438)
2019 F150 (A56438)
LIGHT TOWER (A56857)
