3-Point Hitch 3 point on Ford 6640 stuck in up position
   / 3 point on Ford 6640 stuck in up position #1
Southerj
Ford 6640
My 3 point hitch on my Ford 6640 is stuck in the up position. I am not sure how to release the pressure and get it down.
   / 3 point on Ford 6640 stuck in up position #2
Is the draft control lever in the up position? Put it in the down position and try it.
hugs, Brandi
   / 3 point on Ford 6640 stuck in up position #3
Check all your linkage make sure nothing has loosened up or fallen off. Hopefully you will find something on the outside. Our problem with our 6640 was it wouldn't raise and we finally found bent/broken linkage internally caused by a worn bolt head. Here is the link to the thread on our 6640 3pt problem
Ford 6640 3pt hitch problem
Good luck with your problem
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2019 FREIGHTLINER...
2003 Big Tex 10PI...
