3320 pics
/ 3320 pics
Here is a preview.
/ 3320 pics #3
Nice pictures, You will enjoy the 3320! I know it's the best money I have ever spent, the MX6 will be a beast also I have the MX5 and it is a awesome cutting machine!
/ 3320 pics #4
Sweet new 3320! And love the pictures! :thumbsup::cool::D:p
/ 3320 pics
I traded in my x720 with 62" deck for the 3320 with 72D". This will give me more flexibility in running multiple implements.
/ 3320 pics #6
You should hook up the aerator to the 3320 that would be a great combination with the mower!
/ 3320 pics #7
What are you using the loader ports for? Is the scv selector handle a new option? That's quite a step up from a lawn mower to 3000 series. Are you using these deere's for work or at home?
Matt
/ 3320 pics
-Control for raise and lowering deck-
-It is the new way for Deere to put remotes out the back. All electro-hydraulic now vs the old 3rd scv seperate lever-
-Little bit of both...I have several acres that I maintain for others plus my own land-
/ 3320 pics #9
Sorry. Just found this. Nice!!!!!!!!
/ 3320 pics #10
Awesome combo!
You're a lucky man. :thumbsup:
/ 3320 pics #12
Very nice pics! :thumbsup:
I always liked the 3320 (especially with the cab, but I see you already have a larger cabbed Deere)...Let us know how the 3320 works out for mowing...A little bigger then the X...eh? ;)
/ 3320 pics
Yes it is a bit bigger than the x720 but I think it will work very well for my mowing. I like the idea that I can use either tractor with most of the implements.
/ 3320 pics #14
Oooo. That's what my 2520 wants to be when it grows up. :drool:
I think that was wise to take the bull by the horns and jump straight from the X to the 3000 series, assuming there is a need for such equipment of course.
/ 3320 pics
I have owned a variety of tractors in the past 10 years. I knew the 2x20 was not the way for me to go. I have owned the following and probably more...
JD 285
Ford 1600
Kubota B7500
JD 4500
JD 4115
JD 4120 (x2 2004 and 2008 models)
JD 5203
JD 2520
JD 3320 (x2 2007 and 2011 models)
JD 2320
JD 445
JD x485
JD x720
JD 4720 CAB (current)
/ 3320 pics
Does anybody here have experience with the 72D auto connect?? Any tips or advice for taking the mower on or off??
Thanks!
/ 3320 pics #17
don't try to attach or remove the mmm with the fel mounted. it will hit the front link and on mine bend the spring loaded rod. remove the fel first. bud
/ 3320 pics #18
Very nice setup! :thumbsup:
Did not consider that many of the attachments will be interchangeable between the 4720 and the 3320... that will give you added flexibility as well as efficiency!!
I also noted that you worked out a compromise with your dealer on the MX-7...
With the 4520-4720 horsepower increases on the 2009 models it would seem to make sense that Deere would reconfigure the MX-7 to be iMatch compatible. Both tractors (with proper ballasting) should be able to handle the larger mower in most situations.
Deere's missing out on some sales and satisfied customers!
AKfish
/ 3320 pics
Yes I was very disapointed to find out the mx7 was not setup for imatch even though the sales manual says it is.
2013 Komatsu PC360 Excavator (A60352)
2013 Komatsu PC360...
EZ-GO SHUTTLE 2X2 TXT GAS GOLF CART (A63276)
EZ-GO SHUTTLE 2X2...
2010 Deere 318D (A60462)
2010 Deere 318D...
2007 Jeep Liberty 4x4 SUV (A61569)
2007 Jeep Liberty...
2020 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A61573)
2020 Autocar...
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
