Buying Advice L3800 or MX4700 or MX5100?
   / L3800 or MX4700 or MX5100?
Well, just got back from the dealer, and it unfortunately didn't go as planned. It was a non-HST model, so I didn't even bother to compare them driving wise, obviously. He's going to check his other dealership and see if they have another one I could test back to back against the L3540 and go from there. Just initial speaking, though, size wise there's definitely a substantial difference between the L3800 and L3540 in nearly every respect. Plus, I'm leaning more towards to the Grand L now, because I think the features are probably worth it, without even having to drive the L3800 to compare the lack of the HST+ features.
I really appreciate everyone's help,
Chris
   / L3800 or MX4700 or MX5100? #102
What prices are they giving for each... I think you said the Grand L3540 was about $27,000.
Well the sticker differences are roughly $6K, and I didn't ask about the price difference after discounts. I was frustrated it wasn't a HST so I could really see the differences while driving.
A couple things I didn't like about the L3800, though:
1) The steering linkage is full exposed up in the front of the tractor with no guards
2) On the right side, some of the hydraulics and what appears to be an oil filter of sorts is the lowest hanging part of the tractor, leaving them both pretty exposed, as well.
3) The 3-point hitch doesn't telescope at all(harder to hook up attachments), plus it has to be held together with a strap in the center to prevent it from rubbing the tires.
4) Can't add rear wheel weights to the L3800, plus it weighs approx 700 lbs less than the L3540, so the combination of the two probably means the loader would suck in comparison to the L3540 stability wise.
5) The seat is nicer on the Grand L - High back with armrests versus low back and no armrests, plus the adjustment for the seat spring is in the back on the L3800 and it's an easy to reach knob on the Grand L
6) The hump in the floorboard is substantial in the L3800 in comparison to the little hump on the Grand L.
7) I can see the lack of the tilt wheel would be annoying on the L3800, as well, because it's actually a pretty good reach to the steering wheel, and I'm 6'2".
8) I can't comment on the HST differences unfortunately.
9) The loader looks quite a bit beefier on the L3540 than the L3800, not to mention the standard size difference of 6" of box width and the extra lift capacity. Plus, if you opt for the HD loader, it's even more capacity and width.
10) I didn't get a measuring tape out to check diameters or anything precise, but the tires are quite a bit bigger, as well.
11) The rear axle appears to be quite a bit difference and beefier than the L3800 too.
At any rate, a lot of this I bet all of you know already. Maybe it will help some other newbie like me to decide on their own too. To me, I think it's still worth a drive on the L3800, but honestly, I'm leaning towards a Grand L model at this point. I'd almost think moving up to a MX5100 would be more likely of an option too, but who knows at this point. I'm still considering all my options I guess. Not an easy process, that's for sure.
Chris
   / L3800 or MX4700 or MX5100? #104
Shoot, if I had the money I would have a Grand L!!! This is where you have to decide what is better for yourself (but I do like the comparison!!!) A few comments about what you wrote...
1) The steering linkage is full exposed - Yes, and I've bent mine.
2) hydraulics and oil filter is the lowest part - yes, but I don't go in the woods enough to know if it's bad, it hasn't been a problem reported on TBN
3) The 3-point hitch doesn't telescope Correct but Adding Pat's Quick Attach is much easier than telescoping ones.
4) Can't add rear wheel weights to the L3800, plus it weighs approx 700 lbs less than the L3540, You say that like it's a bad thing :D The loader will most likely be more than you'll ever need but maybe I'm wrong, it's more than enough for me.
5) The seat is nicer on the Grand L - You got me there, but for $6,000 it should have air suspension seat.
6) The hump in the floorboard is substantial in the L3800 in comparison to the little hump on the Grand L. - Ok, yes
7) I can see the lack of the tilt wheel would be annoying on the L3800, as well, because it's actually a pretty good reach to the steering wheel, and I'm 6'2". I'm the same height but the $6,000 in my back pocket puts the steering wheel closer (sorry I should filter some of my thoughts) Never notice the steering wheel as a problem since I'm always using it to get on and off the tractor.
Back to black and the weight of the tractor... I drive the tractor in the yard around my house and it leaves enough "dents" in the ground, heavier tractor bigger dents. When it comes to hauling the tractor on a 7,000# trailer (3,500 tractor, 1200 FEL/grapple, 1800 trailer, 500# implement) I'm maxed out. 700 lbs. more and I'm looking for a new truck and trailer... which sounds nice but after the divorce... I'll be selling the whole darn lot...
Size wise, so do you not have many trees? Pretty open space? I've put a couple of holes in my buildings :ashamed: Learning how far out the loader was. Just be careful.
I've beat this horse to death and then some... let us know how it goes.
   / L3800 or MX4700 or MX5100? #105
Also add to your list the smooth operating 3 pt hitch hydraulic system vs the jerky Lxx00 system.
The requirement of a strap you referenced in item 3 I assume is because it has turnbucles for stabilizers instead of telescopic. The B's also have them but they are on the inside so the arms sag to the middle when there is nothing on the hitch. I hated them and after bending the 2nd one I replaced them with telescopic stabilizers for about $200 extra.
   / L3800 or MX4700 or MX5100? #106
It's a lot of money, you should think it through. I would try the MX4700/ 5100 as well.
   / L3800 or MX4700 or MX5100? #107
Chris
All good reasons why I prefer the Grand L over the Standard L, the Standard L is a good tractor, my wife and I only took about five minutes comparing the two to decide the Grand L is what we wanted.
The MX5100 is a nice tractor, but doesn't have the HST+ and is a turbo which some people don't like due to the cool down period and worry about reliability. We have a turbo on our M8540 and haven't found it troublesome though it is nice not to have to wait a while for the turbo to cool down before shutting it off. As far as reliability, I don't see any reason for concern, but there is a rather lengthy thread on this and I think it got a bit contentious.
The MX5100 won't be quite as nimble as the 3540, but that may or may not be an issue; decisions decisions.
All good points for sure. I usually go one extreme to the other when buying things. Most our cars are fully loaded top of the line models, but I recently purchased a decent used base model car too, and it's just fine, so I wonder every day I contemplate this if I'm going overkill for the sake of my natural tendencies to do so. Probably, based on your pictures, I need to see more pictures of these smaller tractors doing work, so I can get a better feel of exactly what they're capable of. To me, your 2800 seems to be handling that large tree no problem. Is that a barrel full of cement or something on the back to offset the weight? Your point about the truck and trailer to haul the heavier tractor is a concern of mine too, I guess. We'll be hauling the tractor, what little bit we'll be hauling it, with a tow vehicle rated at 10K lbs, so I'd say I don't want to go too much above your figures either. The grass indents it makes it definitely a concern too I suppose. At times when we'll be leveling our RV sites, we'll have to spend time with the tractor on the grassy parts of the sites to pull the gravel where we want it, so if your 2800 makes pretty substantial indents in the grass, I can imagine these larger ones are going to be way worse. That's something to seriously consider that I haven't really thought would be as big of a issue, honestly.
Thanks again for the insight. Now you've got me really thinking back to getting a more basic, smaller, lighter setup, and save my macho big boy bragging rights for another time...lol.
Chris
I didn't test the 3 point hitch on the L3800 like I had planned, partly because it wasn't an HST model and the other reason is they didn't have an implement to put on the back with test it with. They're not really even fully open as a new dealer yet. I see what you mean about getting the stabilizers as an option...something I'd definitely get if I end up with a L3800 after seeing the standard setup today.
Chris
Yeah, after some more thought, I need to get out of my head any of these bigger tractors, such as the MX series. I think I need to search for some pictures of folks using these smaller tractors to see what they're really capable of. I might end up with a B series...lol. :)
Chris
   / L3800 or MX4700 or MX5100? #111
Chris
Here are a few pics of the type of work I regularly do with my B-series. Hope this doesn't confuse your decision even more. :D
Site I excavated (using loader w/ tooth bar) for a small pole barn:
Also drilled holes, set posts, and set trusses (shhh, don't tell the safety police):
Excavated, graded and spread base material for round pen:
Part of an ATV trail I'm building:
Cleaning up some brush on the farm:
Regardless of the size of the tractor you go with, I think you would be happier with the premium series in each respective class. Skip the standard B, L, and MX, and look at the Premium B, Grand L and the M series. (MX is a basic, small version of the M series, and is actually built on a grand L chassis, but without the grand L features)
Yeah, that didn't make my decision any easier...lol. Thanks for sharing the pics.
Chris
   / L3800 or MX4700 or MX5100? #113
Chris
Here to make it easy:
B3030 or L3240/3540.
You already decided you don't want the standard L, and the MX is too big. So take a look at those two tractors and pick one. See which one you like best and which fits your budget best (including associated implements.) Either would be plenty capable at the tasks you listed, both are very nice tractors.
K I'll check out the b series since I haven't done that yet. Is the B3030 the top of the line largest b sized tractor?
Chris
   / L3800 or MX4700 or MX5100? #115
I emailed him to see what he thinks about his B series and whether he compared it to a L series when he was looking to buy his. Thanks for the heads up.
Chris
   / L3800 or MX4700 or MX5100? #117
Chris
The B3030 is the the largest chassis size in the B-series and also the one with the most features. The B3200 and B3300 have a little more power (on the spec sheet) but in reality they all just have about 30hp. Based on your info the B3030 is the only one I would consider.
On nice thing about the large B series is the long wheel base, in fact it is longer than the L3800 which makes for a smoother ride and better loader operation.
Just for comparison, a well equipped B3030 w/ loader would be about $24000, a L3240 setup the same way (w/ the small loader) would be around $26600. Step up to the L3540 and the HD loader and your looking at $28600. That extra $4600 could buy you a full setup of top of the line implements such as a box blade, landscape rake, mower and grading scraper. BTW, those are list prices off the Kubota website, if you shop around you could get as much as 15% off those.
K, I'm going to look at them to compare. Not to open a whole new can of worms but what's everyone's opinion of the Mahindra tractors?
Chris
   / L3800 or MX4700 or MX5100? #119
Chris
I think I brought them up before(mahindra)maybe check out the 4035.We just got one locally and stopped and looked at them.I dont know enough about them to say anything good or bad. They have have some really good deals on them but never know.
Yeah that's the only one I'd consider I think, but it appears to be a stout tractor from what I can tell from the specs.
Electric Diesel Fuel Pump with Hose Reel (A55851)
Electric Diesel...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
26120 (A56859)
26120 (A56859)
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2015 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2015 CATERPILLAR...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
