Brush hog-access panel
/ Brush hog-access panel #1
flusher
Super Member
Sacramento
Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
I don't like working under my 6-ft Hawkline mower so I rigged up an access panel for blade sharpening and removal.
Layed out the pattern. Drilled 1/2" holes in the corners for stress relief.
Cut the 1/8" sheet metal (it's non-structural) with my 4-1/2" angle grinder.
Drilled some scrap steel angle for 5/16" hex bolts (slip fit).
Welded it up.
Now all I have to do is use a 4x4 and a 2x4 wedge under the blade to keep it fixed when sharpening with the angle grinder. And the large hex bolt that attaches the blade to the stump jumper is a lot easier to access for replacement.
/ Brush hog-access panel #2
Nice work! I have threatened to do the same thing on a Bush Hog 285 for several years. You may have given me the push I need.
/ Brush hog-access panel #3
Will it be able to withstand a rock or large stick hitting it? I can’t make out how it’s attached.
Will it be able to withstand a rock or large stick hitting it? I can稚 make out how it痴 attached.
The steel angle pieces are welded to the mower's sheet metal and to the removable panel. A little dicey with a stick welder on 1/8" thick steel ( sheet metal burnthrough problems if you're not careful). But I used 1/8" 7014 rod, 90 amps/DC+ and it seemed to work OK. And the six 5/16" hex bolts secure the removable panel to the mower. I don't think that panel is going anywhere.
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
PENDING SELLER CONFIRMATIONS (A59908)
PENDING SELLER...
2016 Buick Regal Sedan (A61569)
2016 Buick Regal...
2024 GMC Sierra Elevation Crew Cab 4x4 Pickup Truck (A60352)
2024 GMC Sierra...
